Likes Likes:  1
Results 1 to 10 of 14
Thread: Cdti fuel filter
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Cdti fuel filter
    Hi doing a service on the vec this week just got some mobil 1 0w40 fully synth. For it and oil filter for 40quid delivered with opie oils and it's 5 litres
    Bought a fuel filter off eBay I have read the how 2 and every one says don't break the black tabs on the pipes when you take them off I though it's just a case of getting a screwdriver in pushing in the locking button at both sides then pulling the pipe off
    Can any one help me or give some advice for thus as it's my 1st time for a fuel filter change cheers guys
    Farnborough, Hampshire
    Hi
    I did mine recently, there is a clip on the front and backside of the pipe which both need to be pressed simultaneously. I think VX have a tool for this but its perfectly doable with a small flatblade screwdriver. Go gently and i can't see you having a problem at all. The worst bit is going to be getting that damn lid off!! ;-) i used a gripper thingy and it really did require some brute force.
    Enjoy!!
    Engine : 1.9 CDTi
    Pretty sure the engine takes more than 5 litres of oil too.
    kings lynn, norfolk
    Ok cheers I will let you guys know how I get on
    I though the 1.9 cdti takes only 4.7 litres of oil
    Bristol
    Vehicle : CDTI 150
    CDTI takes 4.3 ltrs and the DTI 5.5 ltrs.
    As danman says just take care with a flat bladed, a bit at a time.
    Agree, the securing ring can be a pain to remove.
    Hope it goes well
    Engine : 1.9 CDTi
    Ah its the DTi that takes more
    kings lynn, norfolk
    cheers i will update once i have done it or i get stuck doing it lol thansk guys
    kings lynn, norfolk
    Hi guys took my fuel filter out using 2 small screwdrivers to take of the fuel pipes then the filter poped out of the housing and took of the electrical plug
    Drained the fuel via the tap then put
    In vice managed to
    Undo lid by hand took out filter but problem is the new one I ordered is the wrong
    One so had to put old one back in
    I ordered it off eBay for my car exact write up but re fuel filter turne up is pleated paper and has a hole at either end where as the one that is fitted is like cotton wool with embossed circles and one hole at one end so
    Must be wrong
    Will be getting the correct one tomorrow from halfords ad sending the wrong one back
    What a pain in the bum! Got mine from autofactors for £11 if thats cheaper than halfords?
    preston
    hi
    its probably ok. the white one with emossed circles is the GM one - turkish made i think
    I've used a pleated one when i replaced my GM one and it works fine.
    just depends what they supply i guess
  1. Oil and fuel filter 1.9 cdti 150
    By chay6684 in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2012, 08:07
  2. fuel filter 1.9 CDTi
    By chrisgettings in forum Diesel Engine related
    Last Post: 30th January 2012, 14:33
  3. fuel filter cdti 150 .
    By dave r in forum Engine & Drivetrain
    Last Post: 14th April 2010, 20:22
  4. cdti fuel filter
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 19:23
  5. Cdti Fuel Filter
    Last Post: 11th June 2008, 22:14
Cant get fuel filter off to 1.9cdti
