Thread: New member needs your help
    Aug 2010
    york
    Default New member needs your help
    Hi To you all,
    I am new to this forum, i have got a vectra sri 2.2 dti 2003.
    Its been a great car for years but lately had afew problems.
    i.e front/rear springs snapped at bottom where it sits.
    Tension rollers worn (auxilery belt ) causing rattle noise.
    Solenoid valves ( lack of power )
    The prob ive got now is another rattle / whining noise think its the gearbox, car only done 72000 miles .
    Can hear noise more at low speed .
    Has anyone had this prob with their car ,
    Any help would be much appreciated
    Cheers Tomo
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by tomo610 View Post
    Hi To you all,
    Cheers Tomo
    Welcome mate, you'd be best fitting a full set of aftermarket springs as they will just keep breaking, (common fault)
    It's the damper on the tensioner that seizes causing the belt to chirp but if its definatly a rattle get the timing chain checked
    As for the lack of power, clean the EGR valve and boost senor
    Your gearbox noise is more likely to be a knackered wheel bearing
    Aug 2010
    york
    Hi John
    Thanks for reply ,I should have made it clear that ive had springs,tension roller and valve fitted.
    can the egr valve be cleaned on a 2.2 dti ? i was told the not as different to the 1.9 dti valves.
    Ive had wheel bearing checked and all ok.
    CHEERS TOMO
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sorry mate, didn't realise you'd had the stuff done.
    How was the wheel bearing checked as they can whine but not have any play in them. Worth swapping tyres front to back to see if that makes a difference.
    The egr is pretty easy to clean on the dti. In fact if you look in the how2 section you'll find a how 2 for it
  1. member
    By WKD-mcc in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 15:15
  2. new member
    By lowsri in forum Introduce yourself.
    Last Post: 19th July 2009, 20:31
  3. member stats and latest member...
    By LJ sxi-nav in forum General Chat
    Last Post: 23rd February 2009, 20:48
  4. FAO 420keithp EBAY member who's a vec C member
    By Silver V in forum General Chat
    Last Post: 28th December 2007, 22:13
