Results 1 to 10 of 13
Thread: Where is the switch on the clutch pedal?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Default Where is the switch on the clutch pedal?
    Hi all,
    As the title. I'm trying to clean or replace the switch on the clutch pedal, but can't locate it Anyone know where it is, or even better, have a picture?
    Many thanks.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    what switch is that mate
    Dunstable
    Guessing it's what dis-engages the cruise control when the clutch is pressed?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    why u need to get to it ?> ................u need to remove the pannel under the steering colum ......... if your cruise control isnt working it will be the clutch pedal return spring that is broken and it will need a modded part fitted to fix it ....
    Dunstable
    Or the stalk that controls the cruise control...
    On another planet
    Engine : 2.0
    Thanks guys - it is because of the CC.
    The stalk is Ok, took that out and cleaned and tested Ok.
    But the CC still drops out.
    I have the Clutch return spring in and it's working fine, so i can only assume that the switch on the pedal is faulty (or something else) so i'm going to try that first.
    Benny - you said i need to remove the panel under the steering column - is that the one above the pedals? Cheers.
    Feb 2006
    dudley
    yep mate ..has some screws along the lower edge and just bellow the colum lower cover ....
    On another planet
    Engine : 2.0
    Many thanks. I'll try that in the morning when sober....
    Regular Member LADmachining's Avatar
    Hampshire
    It is quite likely that the switch just needs adjusting.
    Once the switch is located, press the pedal down fully, then pull the plunger of the switch fully out. This is an exercise in flexibility, and the plunger is stiff to move against its ratchet.
    When this is done, release the pedal, and the switch will be heard to self-adjust.
    On another planet
    Engine : 2.0
    Cheers for the help guys. I've removed the switch on the clutch! (what a ******* to remove) nearly did my back in! I cleaned it and then refit. Also had a look at the brake switch (same as clutch switch) and cleaned that too.
    Been on a 1/2 hr drive and the CC hasn't dropped out once. So i think the problem was either clutch or brake switch (but doubt it was the brake).
    Happy once again.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. For Sale: Clutch Pedal Switch (cruise control)
    By Big Knox in forum Parts for sale
    Last Post: 30th April 2011, 09:15
  3. Changing clutch pedal switch
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2011, 18:52
  4. Clutch pedal
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th January 2011, 08:38
  5. brake pedal switch
    By crucial in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 03:09
what does the clutch switch in a vectra c
vauxhall corsa clutch switch
corsa c clutch switch
pedal stalk vectra c
vauxhall insignia clutch sensor
clutch switch vectra c replace
cluch switch vectra c
can i remove my clutch pedal switch on a vauxhall combo
can I change the clutch position switch on an insignia
what cwitch is on a opel corsa clach pedal
removing a vauxhall corsa d clutch switch
vectra vxr cc switch
vectra c cruise control pedal switch
vectra c clutch pedal switch
location of cruise control clutch switch Vectra c
vauxhal signum cruise control switch location
location cruise control clutch switch Vectra c
vectra c clutch switch removal
clutch pedal switch vectra c
vauxhall zafira clutch switch
how to remive clatch pedal in vectra c
how to remove clutch pedal switch on corsa c
vecgra c clutch switch
Vectra clutch switch
vectra c cruise control clutch switch
