Thread: wing mirror cover removal
    Regular Member booker413's Avatar
    West sussex
    confused wing mirror cover removal
    as per title a have to remove my wing mirror cover for painting,,,, how do i do it????????????
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Some say push the mirror in fully on the car body side then take a screwdriver and gently push through the gap on the outside of the mirror and it will pop off, I just used a screwdriver along the edge of the cover and it pops off quite easily, think its only 2 "push" clips that hold them on, 2 or maybe 3 cant fully remember.
    Regular Member VECTRA HEAD's Avatar
    Derry
    Firstly move the mirror glass inwards towards the car,then use a flat screwdriver and place it behind the mirror glass,the glass should pop out without to much effort,dont forget to disconnect the wire for the heated mirrors,now you should see the clips on the inside of the mirror casing,just squeeze these together and push gently to free from the housing,once these are free there is a small plastic pin left to ease out beside the inner part of the mirror,the cover should now be removed.Hope this helps
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    is the best way
  1. passenger wing mirror cover
    By kenp in forum Parts for sale
    Last Post: 9th April 2010, 19:35
  2. Wing Mirror Removal
    By curly in forum Bodywork & Interior
    Last Post: 1st December 2006, 16:20
insignia wing mirror cover removal
signum wing mirror shroud removal
