Thread: diesel oil ment to be black?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default diesel oil ment to be black?
    this is another oil thread, is the oil in diesel cars ment to be black? i dont mean putting black oil in i mean all the diesel cars ive owned after an oil change the oil is still black its a clear black tho not a dirty black if you kow what i meam,
    i was told because its a diesel it will be black is that true?
    this oil ok for a dti?
    5W-30 fully synthetic (castrol website)
    Regular Member crespo's Avatar
    Bournemouth
    5w 30 fully synth is perfect. And yes oil does go black after a period.
    The oil should be clear for about 2 weeks
    After that I would expect it to be the same consistency but much darker
    After 10K miles I would expect it to be a dark black
    Regular Member Rab's Avatar
    Irvine
    aye diesels turn there oil really black very quickly no big deal.
    Oct 2009
    Sandwell
    sorted, cheers thats put my mind to rest
    changed oil and filters before but not on this vectra c is this the filter?
    see pic is it in that place under the engine cover??
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    yep it has a 36mm hex head on it
    Aug 2010
    Leeds
    It's the soot that gets in the oil and turns it black not to worry.
    north east
    my 2.0 dti you couldnt tell if it had a oil change or not even with a flush it went black as soon as it was started up, the 1.9 cdti though is more yellow even after 2000 miles :-)
    london
    In Diesels, Does the Turbo uses the Engine oil to cool itself as in petrol Engines? If so, it could explain (in addition to soot) why diesel oil goes dark quickly..........any suggestions?
    Naturall aspirated diesels also turn the oil black quickly
    It is due to the high contents of sodium [longname chemical], which is also acidic
    Modern (current) synthetic long life oils can cope better than older "diesel" grade oils, quite often these oils were saturated by 10K miles, hence why the service intervals were typically half those of a petrol engine
  1. How often are you ment to change cam belf on vectra 1.9cdti 150?
    By shearzy in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2009, 20:08
  2. Replies: 6
    Last Post: 31st August 2009, 16:32
  3. Diesel Engine Oil Black??? HELP!
    By s0501291 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2009, 22:45
  4. Aren't Cats ment to be good with trees?
    By AndrewTi in forum General Chat
    Last Post: 3rd April 2006, 19:53
