Thread: Drive Shaft Inner Boot
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default Drive Shaft Inner Boot
    I have a split on the n/s inner drive shaft boot.
    Has anyone had a drive shaft off? Do they just pull out of the gearbox like the old vauxhalls without draining the oil or will the box need drained?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Got mine done at vauxhall mate iirc it was about £50-£60 so i thought id just let them do it
    Irmscher Insignia CDTI 130
    Regular Member Dazzy2006's Avatar
    Notts
    Cant you still get those kits where the new rubber has to be glued together?
    This type of thing!
    http://cgi.ebay.co.uk/UNIVERSAL-SPLI...es_CarParts_SM
    Regular Member vauxhall-john's Avatar
    fife, scotland
    ive used those kits in the past and tbh they are a bit of hit and miss, better off buying a genuine one from stealers, then jack the side up your doing as high as you can to shift the gear oil over to oposite side, pretty sure the shafts still pull out like the older vec b's just have a clean rag ready to jam into the gear box where you pulled out the shaft to stop the oil coming out,
    as for the cv joint coming apart im not sure if its still the old circlip style where you get covered in grease or not,
    Jan 2008
    Dundee
    Quote Originally Posted by vauxhall-john View Post
    Agreed. might just book it in
  1. Drive shaft
    By drummo in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2012, 13:50
  2. Inner drive shaft boot
    By damoore1983 in forum Engine & Drivetrain
    Last Post: 28th July 2009, 08:00
  3. drive shaft boot
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2009, 11:11
  4. Inner Drive shaft boot
    By jamesr in forum Engine & Drivetrain
    Last Post: 10th November 2008, 21:37
  5. drive shaft
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2008, 12:44
