Thread: Lambda question on 2.0T
    Full Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    Default Lambda question on 2.0T
    Okay I need a little advice. My Emission light comes on randomly and stays on (the engine symbol,not the car and spanner).
    Plugged into diagnostics and there are no stored codes or faults, so once cleared it goes away, but will come back either month later or two weeks later.
    When engine is at operating temp, the Exhaust Gas Temp. reading is always -6.5 - actually it's always reading this - and the loop is switching between open and closed. Is it feasible to think that because of the lazy sensor it will throw the light on, but not store a code?
    Apr 2008
    suffolk
    So no one got any ideas?
    Regular Member sberrow's Avatar
    Newport (Gwent)
    You running any mods to the engine or exhaust
    Apr 2008
    suffolk
    No. Standard. It's gotta be related to the loop switching constantly or the odd reading of the gas temp....how can it ever be minus anything?
    [Ex]Admin Duncan's Avatar
    I've had the same light (emissions) pop on every now and again - steady, not flashing (if flashing then you need to stop driving ASAP). As with you, no codes stored and once cleared it wouldn't happen again for yonks. It only ever happened at start-up and usually when it was cold outside so I just out it down to the car not being warmed up, fuel not burning fully etc. etc. and the sensor just being a fit finicky
    As mine is mapped then I thought that may have been a contributing factor. I can't recall the last time it happened so can't suggest why your standard car is doing it so often.
    Apr 2008
    suffolk
    No it's not flashing, but just comes on. As said, there are no stored codes so leads me to believe that it's just a momentary anomaly/abnormality. Think I;ll reset it, run it on shell or BP (I use Esso atm) and see if that helps. If not then I'll change the sensor, as the fact that it reads a temp of minus anything can't be correct. Local VX dealer said that even though there is no error code stored, they's recommend changing the sensor anyway.
  1. EML 2.0T Lambda or CAT
    By a1ant in forum Vectra C / Signum Troubleshooting
    Last Post: 20th August 2011, 20:53
  2. Cat Or Lambda
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 21:03
  3. Lambda help
    By Barnes in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 20:42
  4. Lambda
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 10:33
  5. lambda question
    By Morephun in forum Engine & Drivetrain
    Last Post: 17th June 2008, 20:48
