Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Signum 2.0T ~ No Boost?
    Regular Member sol's Avatar
    Farnborough
    Engine : 2.0T
    Mileage : 52000
    Default Signum 2.0T ~ No Boost?
    Looking for some help!!
    Turbo does not appear to be spooling up at full throttle, although it does on partial throttle.
    Any ideas??
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    Quote Originally Posted by sol View Post
    Any ideas??
    We've just replaced our turbo as ours gave in
    Was fine driving until you came to a complete standstill and then the car struggled like hell to pull away.
    Full Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    Any ideas??
    Do you have the engine management light come on? These engines have a well known fault where the diaphragm in the RDV splits and will put it into limp mode thus reducing your boost. Although it wont ALWAYS bring this code up. Similarly a faulty valve that costs a tenner will give you the same fault, but judging from this forum (and my experience) it's been the diaphragm.
    Farnborough
    Engine : 2.0T
    Mileage : 52000
    Quote Originally Posted by ROCKATANSKY View Post
    No engine management light or limp mode. What is the RDV, and what valve are we talking about?
    WGAF#5
    its the Recirculating Dump Valve - thats bolted onto the turbo - that houses the diaphram
    what mods if any do you have on the vehicle
    Farnborough
    Engine : 2.0T
    Mileage : 52000
    No engine mods at all yet, have'nt got that far.
    Its a 2005 plate with only 32k on the clock. Is this diaphragm easy/cheap to replace?
    WGAF#5
    the recirc dump valve is mounted on the side of the turbo its held on by 3 bolts ...the repair kits about £100 and consisits of a gasket a diaphram a seating cup and a replacement spring ..its not easy to access but it is "doo able" whilst still fitted ....
    i would be checking and double checking everthing else first though as the diaphram usually fails on higher mileage "mapped" cars - i suspect that you may have a pinhole leak on one of the feed pipes or one of the 2 x solenoids might be sticking
    does the fault occur EVERY time you drive the car ? with the RDV the vale would work and then you might feel a lump on accelerating - then the car looses the turbo completely
    Farnborough
    Engine : 2.0T
    Mileage : 52000
    No, it doesn't happen all the time, on light throttle its ok, it's only when you really put your foot down there's nothing.
    Farnborough
    Engine : 2.0T
    Mileage : 52000
    Just taken it for a spin, now got the spanner light on if that makes any difference?
    Regular Member Jezzy's Avatar
    S.E
    Yes - it means you can now get the code(s) read, which may well give a big clue as to what the cause is.
  1. can u adjust stock boost solenoid on 2.0T signum
    By total_vxl in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2010, 20:07
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
vauxhall signum 2.0t lack of power when hot in first and second www.vectra-c.com
signum 2.0 t common faults
