Results 1 to 10 of 14
Thread: Swirl pot rod what do I need to replace
    Jan 2010
    Scotland
    Default Swirl pot rod what do I need to replace
    Well my veccy felt down and not pulling well a quick look revealed the swirl pot linkage was off and making a bid for freedom
    Nit going to mess around and I'm just going to fit the revised manifold.
    My shopping list so far
    Inlet manifold
    Inlet gasket
    Coolant
    Anything else I need I did see someone mention an actuator but is this really needed? No 3 pot still seems tomspin quite happily when revved so at least I know it's just the posh linkage.
    Spec me a shopping list pls guys
    Regular Member bunsen1's Avatar
    suffolk
    ebay, vauxhallparts warehouse , i purchased a manifold with gaskets for £166.50 delivered
    get 1yrs warranty on the part
    Regular Member s-owen4's Avatar
    Aug 2010
    Consett
    Hi Toast
    Unfortunatley you will need to replace the actuator motor when replacing the inlet manifold, I recentley replaced mine without the doing the actuator and had to go through the whole procedure again. I would advise you to get a few various jubbilee clips as you will need to replace a few of the clips you will remove. Probably worth doing the timeing belt as well, if it hasnt been changed.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    good luck makes a massive discount
    Wales, UK
    It doesnt look too hard to change the inlet on the 1.9, have looked into it out of curiosity and was quite suprised lol
    Jan 2010
    Scotland
    Inlet manifold
    Inlet gasket
    Coolant
    actuator motor
    anythign else?
    for what its worth my local dealer are pretty keenly priced for it(albeit trade sale) iirc its working out around £170
    Jan 2010
    Scotland
    Now one question is there any coding or tech2ing that will be needed or am I good to just fit a manifold and actuator and go
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Never changed the actuator on mine!, dont bother, its possible to change it after if needed. if its not broken i would'nt bother, people keep going on about it learning its movements but my local vx main dealer dont change them either!. It returns back to a set resting point via a built in 'stop' and has a very strong return spring!!. and when it moves to open it can only go to its opposite 'stop' no further!!.
    Regular Member mozzer99's Avatar
    bristol
    Quote Originally Posted by mark_647 View Post
    Wouldn't quite agree!
    The Haynes manual is written with the engine out - making it all seem fairly easy.
    Many of the nuts and bolts cannot be seen except with a mirror and undone by feel. It really is a pig of a job for something that would normally be so simple.
    Clamping the high pressure fuel pump pulley and then releasing the pump (one nut is 4 inches back in a hole - drop that nut and .......) whilst leaving the cambelt in place is a real pain just to reach one manifold nut and so on.
    Really glad I don't do those for a living.
    Jan 2010
    Scotland
    anyone have any more input on changing/not changing the actuator. its a pretty big saving if i dont have too
  1. Cim Replace
    By Markov in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2012, 22:58
  2. Can i rip out and replace?
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2012, 11:17
  3. Replace 215/55/16 with 195/50/16
    By battsman in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2012, 16:18
  4. Replace my TID with a dvd?
    By ryantcb in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 15:46
  5. Tie rod replace
    By blackveccyC in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2010, 15:15
vauxhall cdti swirl pot rod
swirl pot activator
