Thread: T/C switch?
    Regular Member blr123's Avatar
    Dundee, scotland
    Default T/C switch?
    Hi guys,
    I've had a search but can't find the definative answer...........so here you go: -
    My car is a 2004 Signum 2.2 Elegance, the question is am I likely to have the switch behind the blank and is it just a case of prising the blank off and pushing a switch in.......yeah?
    Bryan
    a bit like that bryan...
    if you pull the blank off and theres a blue plug behind then you're on your way..the plug is a push in, avaliable from VX and the part number is listed in the P/N forum..
    then it's a 50/50 chance it will work for you or not.. no sure fire garuantees offered and it's not something that you can turn on with tech2 apparently.. so it'll either work or not..
    When Duncan bought a switch recently it was only around a tenner..
    Dundee, scotland
    Sooo a switch just like this one yeah: -
    http://cgi.ebay.co.uk/Vauxhall-Vectr...QQcmdZViewItem
    Bryan
    Here, there and every where!
    It depends whether you have a full canbus car or not Bryan. What i have found is that if you have 3 button controls on your steering wheel then it should work. If, like mine, you have the wheel type controls, it probably won't.
    Dundee, scotland
    Oh I think it's the 3 buttong cotrol on the S/Wheel.........I'll get a switch and see what happens eh
    Thanks guys.....I'll let you know
    Bryan
    Dec 2005
    In the sponge-monkey tent
    Quote Originally Posted by blr123
    Bryan
    Go for it Bry, if you have the blue plugs but the switch doesn't turn TC off, the light should still work and it'll look good anyway mate
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. t/c switch help
    By kitchcav in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:02
