Results 1 to 3 of 3
Thread: Help with fitting an aftermarket head unit.
    Rotherham
    Default Help with fitting an aftermarket head unit.
    I have a 2003 Vectra C Hatch.
    The on/off volume button has packed up for the second time on my CD2005 so I have removed it and ordered a new Kenwood head unit.
    I have also ordered the Autoleads FP 19 00 GN gunmetal facia adapter, aerial adapter and the ISO Vauxhall wiring loom adapter.
    The Kenwood unit comes with a metal cage, do I need to install the cage or will the unit slot in on the original Vectra C brackets?
    Is there enough room behind the facia adapter for all those connector blocks?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    What is the wiring loom adaptor for? The only adaptor you need on the half can Vec's is for the steering wheel controls.
    Is the stereo double din or single?
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by alembicbassman View Post
    Put the new facia in then place the metal bracket into the facia and push on the metal clips top,bottom and sides to secure it then push the iso connectors together add the ariel adaptor push the radio in 'til you hear it click. Job done.
  1. Aftermarket head unit
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2011, 20:23
  2. Help fitting double din head unit... aftermarket cage question?
    By Deann in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2011, 10:23
  3. Help with aftermarket head unit
    By siross in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2008, 12:39
  4. Does having SatNav on Vec mean you can't fit aftermarket head unit?
    By Rikkiola in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2008, 21:03
  5. What do u lose on display when fitting aftermarket head unit?
    Last Post: 14th March 2006, 22:57
2003 vectra c aerial adapter
