Results 1 to 10 of 18
Thread: loosing oil & smokey exhaust!
    Jul 2010
    lancs
    Default loosing oil & smokey exhaust!
    hi,
    Got a 2003 Vectra C 2.2 SRI petrol. It keeps loosing oil, have to top up every 300 miles. The exhaust is very smokey, so assuming burning oil. Can see any leaks anywhere.
    Any advise where to look? or common problem that can be fixed???
    Richard
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Richard
    Sound's like you have piston ring failure.VX had a problem and fitted modifieid rings on all the Z22YH engines,and on Z22SE between engine No's 11 300883-11 378500
    Jul 2010
    lancs
    how can i tell my engine number?
    is it an easy job to do/expensive?
    Jul 2009
    Engine : 20 Dti
    it's stamped on the engine block in the front of engine low down,
    not a job you can do yourself,a complete engine strip down,the labour will turn it into a very expensive job.
    Jul 2010
    lancs
    is there an easy way to know if that is the problem??
    will VX repair for free?
    Jul 2009
    Engine : 20 Dti
    You can have a compression test done,VX won't do anything for an 03 motor.any good workshop will do test doesn't have to be a dealer.(or stealer)
    Jul 2009
    Engine : 20 Dti
    un less of course you have just purchased the car S/H from a VX dealer
    Jul 2010
    lancs
    does it cost much for compression test??
    Jul 2010
    lancs
    will it cause any damage if i carry on driving it for a few weeks until i can afford to take to garage??
    Jul 2009
    Engine : 20 Dti
    if it is rings and you keep it full of oil you should be ok,just don't thrash it as this will use more oil,how long has it been using oil.
  1. Smokey Vec
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 15:57
  2. Help with smokey van please
    By sberrow in forum The 'Off Topic' room
    Last Post: 31st March 2009, 07:57
  3. Smokey SRi
    By MarkEllo220864 in forum Engine & Drivetrain
    Last Post: 28th March 2009, 23:56
  4. Smokey Sri
    Last Post: 27th March 2009, 11:56
  5. Smokey CDTI
    By MattW in forum Diesel Engine related
    Last Post: 21st September 2008, 00:32
