Here is the link
http://cgi.ebay.co.uk/CAR-REVERSING-...es_CarParts_SM
You get the correct size hole saw with the kit. I just drilled pilots first.
I took a live feed from the nearside reversing lamp (white and black wire at the bottom of the plug) and used a scotch lock clip, then earthed to the lamp unit retaining studs.
I fed all the wire through a grommet that was present after removing my toe bar electrics and mounted the control box beside the rear fuse box.
The measurement (B) is distance between the sensors. I started by measuring (A) from the numberplate recess
I hope this helps
