View Poll Results: Any problems or breakdowns with 2.2 DTI engine
Voters
419. You may not vote on this poll
  • yes, several
    122 29.12%
  • yes, only one
    84 20.05%
  • no
    213 50.84%
Page 1 of 25 12311 ... LastLast
Results 1 to 10 of 242
Thread: 2.2 DTi Owners.
    Feb 2006
    Guttedsville
    Default 2.2 DTi Owners.
    It seems to be that the old 2.2 DTi is pretty much the most unreliable engine in the range, no offence to any other members, but can this thread be replied to by 2.2DTi owners with a brief description of any problems or niggles. I expect to be having an interesting conversation with a senior manger at Vauxhall soon, so would like some ammunition to go in with. I am going into bat for all of us now, not just myself. Hopefully the outcome will be positive for EVERYONE who has had problems.
    Thanks for your help.
    Touch wood her ladyship has not missed a beat yet. The only issue we had was of our own doing - trying to fit an induction kit which she took a dislike to and was promptly removed
    I wish you every success in your battle to get yours sorted out though - it is about time this was fixed for you
    Jan 2006
    carlisle
    Default 2.2 dti
    had a 2.2dti B sri which wouldnt start when left uphill- fitted a one way valve which helped.
    i understand that there is a design/manufacturing fault with the leak off pipes but there a upgraded pipe available and also the injector seals need replacing every 15,000 miles
    mike
    Mines the 2.0Dti, almost identical i think, no probs at all in 75k, never renewed injector seals or leak off pipes.
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    had 4 vecs with the 2.2dti and touch wood all been ok
    the one I have now has had trouble when i got it but turned out to be the sim (one of the many ecus)
    no engine troubles after nearly 80,000 miles still goes like stink!!!
    Hertfordshire
    Quote Originally Posted by Andrew's SRi
    It seems to be that the old 2.2 DTi is pretty much the most unreliable engine in the range.
    Sorry m8, but despite my problem, I would say that was rather unfair all things considered.
    I wish you luck, but yours certainly appears to be the exception to the rule.
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    The only issues I had with my 2.2Dti 03 plate Elite after 60,000 miles and three years were a crank shaft seal (Pulley end as opposed to rear main) and a steering rack problem (at which point I traded it in!)
    The engine I had in mine was IMHO superb. Sorry to hear about the issues you are having though mate.
    Feb 2006
    Guttedsville
    Quote Originally Posted by Green Growler
    No offence bud, but take a look at the first page of troubleshooting under the heading engine and gearbox. 2.2Dti this, 2.2Dti that....
    Nr Cardiff
    Rattle rattle boom says it all really!!
    Hertfordshire
    None taken m8, but I have yet to see any real big, main, common problem, time will tell I guess.
  1. All 2.8T owners....
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2012, 21:15
  2. Hello to all VX Owners
    By MattVecVXR in forum Introduce yourself.
    Last Post: 16th March 2012, 11:48
  3. Vec 2.2 dti sri owners
    By SUBEK in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2011, 12:39
  4. 2.0t owners wot mpg u get
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2011, 19:24
  5. !!!Attention all diesel owners!!! (Petrol owners may want a look too!)
    By John LE in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2009, 20:56
vectra 2.2 dti vacuum diagram
2.2dti inlet vacuum valve
agr opel vectra c 2.2
Signum vacuum pipes diagram
opel vectra c 2.2 dti
vacuum signum
vectra c 2.0 dti egr valve
vectra b dti idle air control valve
astra 2.0 dti vacuum pipe diagram
p 0638 vectra c 2 2 dti
vauxhall vectra 2.2 dti vacuum solenoid valve
opel omega 2.2 dti vakum
opel signum 2.2 dti problems vacuum
vectra b 2.2dti idle vibration
omega 2.2 dti bad idle
2.0 dti turbo pressure opel
motor scheme egr
vectra sri 2.2 dti blow off valve
opel 2.2dti turbine workvauxhall zafira 2.0 dti fuel return pipeblow vectra c 22 dtizafira fallo p0234 vauxhall 2.0 dti throttle actuator controlvectra b 2.2 dti boost pipesvectra 2.2 i have a vacuum pipe at the front and i cant find where it goes
