Thread: 4th gear issues
    kent
    Default 4th gear issues
    I've got a problem with the gears crunching when changing from 5th to 4th.
    If im travelling more the 30mph and try to change down the gears crunch in 4th but if i put it into 3rd then 4th its ok. All the rest of the gears are ok going up and down and going from 3-4-5 is ok and smooth.
    Could this be the start of the 4 gear syncro on its way out.
    thanks
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    what engine and box.
    kent
    Sorry should have said its a 1.9cdti 120 with a 6 speed box. Also there is no whines or noise from the box or DMF
    Mileage : 000
    If I remember correctly you might need to drain some oil out. Some one will be able to put us in the picture though.
    I think there was an issure where there was too much oil and VX reduced the amount.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    thats why i was asking drain gearbox oil and refill with 2.2 ltrs
    kent
    Thanks for the advice, ill give that a try next week when I'm off.
    Would the gearbox being over filled be ok one day and then suddenly just start to be a problem.
    kent
    ive ordered a new set f plugs from vauxhall, what oil should I put in. is the vauxhall stuff OK or is there a better oil that someone could recommend.
    thanks
    kent
    ive just changed the oil with vauxhall stuff and the problem is still there.Could it be wear in the bushes on the gear stick as i have just looked at it and there is side to side movement. Hope its not the gearbox and this is will cost mega bucks.
    Full Member Big Sig's Avatar
    The linkage may need adjusting, worth a shot
    kent
    tried to adjust the linkage this morning and ended up breaking one of the grey clip that hold on the cable. Does anyone know if you can buy them and a part number.
    thanks
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Second gear boost issues..
    By unknownbullet in forum Engine & Drivetrain
    Last Post: 26th February 2013, 19:39
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Gear Box Tourqe conv. issues
    By Ean in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2009, 23:25
