Thread: Hid help - pt2
    Regular Member Dazzy2006's Avatar
    Notts
    confused Hid help - pt2
    Following on from this thread
    http://www.vectra-c.com/forum/showthread.php?t=116534
    I dont know if this is normal but i have just fitted the passenger side but if i fit the cancellor the light does not work but if i remove the cancellor and plug directly into the ballast it works perfectly - no strobing/errors on dash etc ........................... so far
    Also will my ballast be safe mounted near the battery?
    Any idea's welcome
    Notts
    Nevermind - i dont seem to need the cancellors maybe their only needed for full canbus cars
    I decided it was best to remove the washer bottle spout to get enough access to fit the passenger side and i fitted the ballast inside the battery compartment
    Next i removed the airbox and decided the best place for the ballast was here
    but i had to shorten this bolt to get it to fit here
    Can anyone tell me whether these are the adjusters for the headlights?
    The difference is amazing so i cant wait to try them tonight
    Notts
    Can anyone confirm whether these are the adjusters for the headlights?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    yep ...and dont forget the electric leveller as well
    Notts
    Cheers - and the headlight washers
