Thread: Faulty REC module
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Default Faulty REC module
    Has anyone here heart about faulty REC modules.
    Both my inner rearlights in the Tailgate (Estate) does not work at all. but reverselight anf fog light works fine.
    I get the Bulb failure every time I start the car.
    The rear lights on the car both works fine..
    I´ve changed:
    Bulbs
    Sockets
    wiring loom in the tailgate
    Rear clusters in both sides.
    Check for bad connection.
    Nothing works..
    And after activating the electric tailgate the car nows thinks the tailgate is open when closed and closed when opened.
    Is it the REC playing up...??
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Free bump for you as i haven't a clue,but it does sound like you have checked everything possible.
    Does Tech2 give you any error codes ?
    Irmscher Insignia CDTI 130
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    the loom breaks where the tail gate hinges are and may pop fuses which possibly may of fried the rec
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    Quote Originally Posted by bigmac View Post
    No error codes other than it comes on with the lights does not work.
    Quote Originally Posted by mattv6diesel View Post
    We have checked the wiringloom. No broken wires and no popped fuses either.
    Checked all fuses in the back, in the dashboard and in the front.. No missing or broken fuses.
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    I will now try to change the REC module.
    Is the REC module the same in all estate´s or do I have to find one with the same Ident code fx. "AR" or "AS" and so on...
    I am aware of the it needs tech 2 coded to fit my toy options in the car, and it of course needs to be decoded before taken out of the bracking/spare car..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    No they are not the same.. diffence in between options in the REC.. one small is eg. Lightsensor in the rainsensor.
    So not sure but think "only" you need to check facelift/not facelift.. have you tried "Terminalen" to check if others fit via EPC.
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    UPDATE!!!!!
    I have found another REC module with the same ident as I have in the car (Ident AP)... Now the taillights works in the tailgate.. So the REC module was faulty in my car...
    Engine : 2.2 Direct
    have you had the programming sorted...
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    No it is not programmed to the car yet.. But it sits in the car now. I will wait with the programming until I have the module in the dashboard. Then go see Michael in Horsens and let him work his magic...
  1. Faulty MAF (I think)
    By gerryo in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 14:08
  2. Faulty maf
    By Mattle40 in forum Engine & Drivetrain
    Last Post: 16th January 2012, 23:21
  3. Faulty airbag module ?
    By CdRsKuLL in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2010, 10:00
  4. Faulty lpg
    By mark88 in forum Engine & Drivetrain
    Last Post: 11th January 2010, 19:44
  5. faulty tps
    By Morephun in forum Engine & Drivetrain
    Last Post: 13th February 2009, 21:19
moduł rec vectra c replace
rec module vectra c
