PLEASE READ DESCRIPTION CAREFULLY!!
SPECIFICATIONS:
Electrical start + Kick start +Electric Key Start (push of a button)
Digital clock
Luggage area under the saddle (for a helmet)
Stainless steel exhaust (performance tecnigas exhaust)
Dashboard in "Carbon" look
Aluminium brake levers
Double Halogen headlight
Colour Coordinated Aluminium rims
Topbox (not pictured bas been removed but still available)
TECHNICAL:
Length x Width x Height 1800(L) x 700(W) x 1100(H) mm
Wheelbase 1270 mm
Ground clearance 90 mm
Net weight 86 kg
Engine mode 1-cylinder, 2-stroke, air-cooled
Bore & stroke 40 mm x 39,2 mm
Displacement 49 ml
Maximum power 3,4 KW / 7500 rpm
Net maximum torque 2,6 Nm a 5300 rpm
Braking method Front wheel disc brake, Rear wheel drum brake
Front wheel size 120/70-12 51 J
Rear wheel size 130/70-12 56 J
Economical consumption of fuel *
Fuel tank volume 4,8 L
Ignition CDI
Compression ratio 7,2 +- 1
Clutch type Dry centrifugal CVT system
Battery 12 V, 4 Ah
IMAGES
SlideShow - http://img823.imageshack.us/slidesho...d=img0166s.jpg
TAKE NOTES:
Even though this scooter is only 3years old and only had one owner, it is in a critical condition so i recommend that it is used for spares or for a restoring project.
This scooter not been activate in 1 and a half year.
FAULTS FROM WHEN LAST ACTIVATE:
-Kick start didnt work properly
-Lost spare key
-Mileage clock was disconnected
-Spark plug Slightly bent
-Engine started to die on hills (unknown reason)
-Big crack on side and front of scooter as pictured
-Bent wing mirrors
All reasons explain why scooter going for cheap, need quick cash so getting rid, not sure how much exactly it will be to restore it as when i first got the scooter back in 2007 it was a brand new model, so the repair garage didnt know much on them.
3 years on now i can guarantee garages will have more info on what is wrong with it and have more parts available to restore it back to a healthy condition!
Please mail me in PM or via email: aaron.peart@hotmail.co.uk, if interested,
£200, offers to be negotiated but no bullsh#t!
PICK UP ONLY
