Thread: Strange Starting issue and Exhaust emission/gases light on
    Leicestershire
    Default Strange Starting issue and Exhaust emission/gases light on
    March 2004 1.8 Vectra Club Estate
    Engine Z18XE
    Car fine until this evening.
    Went to start took a while ticking over (key position 3), Spanner and Car symbol came up then went out released key to position 2 and engine started. Drove to shops.
    Then on return same thing, took while in key position 3, Spanner and Car Symbol came up then went out, released key to position 2 and engine started, but this time Yellow Exhaust Emission/Gases light came on and stays on.
    Have repeatedly done this and Exhaust Emission/Gases light stays on.
    Tried the pedal and key methods to read fault codes but no luck getting the codes.
    I would be grateful for anyone in South Leicestershire/North Northamptonshire with a code reader that I could use? to try and detect codes.
    Is it worth trying to locate and clean the EGR ?
    Any other ideas?
    Nige
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    You need to get codes read really.
    Does your car have a DPF? If it does I'd guess this may be blocked or a faulty sensor.
    However the slow starting would probably be down to a sticking solenoid in the starting motor and wouldn't expect the two things to be connected but you never know?
    Codes needed.
    Bri.
    Leicestershire
    Spoke to a couple of local garages to get in for code reading, earliest I can get is next Wednesday.
    Just to clarify (as I didn't make it clear in first post) that it is a 1.8 petrol.
    One of the garages checked the reg plate and said that the EGR has been blanked on my car, so one thing eliminated.
    Took car for longer drive this morning, acceleration was sluggish and could also feel a judder/hesitation, as if the car was holding back, did this in all gears, but did slowly continue to accelerate and I managed to get to 70, but took longer than normal. Yellow Exhaust Emissions/gases light still lit up continuously.
    Then, after popped into garage to book in for code reading, started car still took a while to turn over, but no car & spanner symbol, Yellow Exhaust Emissions/gases light still lit up continuously. Took car for a spin and acceleration back to normal, no hestitating/juddering. Strange?
    Would the severe rain we had yesterday have caused anything ?
    Any ideas, gratefully received.
    I am now have to wait till Wednesday to get codes read.
    Nige
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Maybe got a bit of water in somewhere it didn't like. The emission light might be down to a faulty lambda sensor. There are 2 on the 1.8, 1 before the cat and 1 after, relatively cheap to replace from ebay/Euro car parts at around £50 each, double that if you buy from a dealer.
    Leicestershire
    Turned out to be a faulty Crankshaft sensor, replaced and all working fine now.
    Thanks for ideas.
    Nige
  1. exhaust gases light?
    By vectra-matt in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2011, 19:42
  2. Exhaust gases warning light
    By CH-VECTRA-ELITE in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 12:01
  3. Exhaust gases light on. :(
    By papz in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2009, 19:36
  4. Exhaust gases light on....
    By rededd in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 20:04
  5. Exhaust gases warning light!
    By eashton in forum Engine & Drivetrain
    Last Post: 30th September 2008, 10:44
vectra c 1.8 exhaust emission warning never light
