Results 1 to 10 of 14
Thread: traction control and abs light on please help!!
    Full Member vectraturbocal's Avatar
    Aug 2010
    leeds
    Default traction control and abs light on please help!!
    just drove home and as i have pulled up i noticed the traction control and abs light on i know it wasnt on when i first got in the car but i didnt see it come on whilst driving not having luck with this car someone please help, thanks cal.
    Aug 2010
    leeds
    Full Member Big Sig's Avatar
    Without fault codes it's a difficult one. It's probably a abs wheel sensor but you needs to get the codes read to find out exactly.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    As the big man said, but as its an 04 plate try taking the ABS plug off, giving it a clean and pop it back on. Chances are nothing will change but its free to try. I had the same as you and cleaning the ABS plug solved it but I had other symptoms as well.
    I forgot that one!!
    VIP-Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    ABS PLUG.
    Bri.
    Today!! The new tomorrow, live the NOW!!
    Aug 2010
    leeds
    i will try that, going to try get it plugged in tommorow if sparky calls to work (basicly lives there lol)
    Solihull
    I've just started getting this problem too. I have a vector c 1.9cdti 05 plate.
    In feb, the abs and TC lights kept coming on and eventually battery went dead. Was the alternator that had to be replaced.
    All problems were sorted. But those 2 lights are now coming on again, once in a while, mainly when manoeuvring sharply in bays, parking spots etc.
    Got the alternator and battery checked and they are still fine.
    Any suggestions? How do I check the ABS plug? I don't even know where it is? Can a novice do it?
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by ishaqmir View Post
    Yours falls outside the faulty ABS plug mate and turning the wheel wont affect the plug. Another possibility could be the CIM as it houses the steering angle sensors. With both CIM and ABS plug faults you might also find all your dials drop. The CIM isn't a DIY job really as it involves Tech 2 support.
    If you still want to put your mind at rest re the ABS plug then all you need to do is pull out the catch on the end of the plug and lift it up but as said odds on it wont be that.
    Aug 2010
    leeds
    i am getting a whinning sound comeing from the alternator area could this be a faulty alternator if so could that be it?
  1. ABS and Traction Control Light..
    By integrale in forum Suspension, Wheels & Brakes
    Last Post: 28th February 2012, 15:17
  2. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  3. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  4. no traction control light?
    By li4m in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2010, 10:42
  5. traction control light
    By chosen1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 09:02
holden vectra abs light on
vectra c abs plug 07 location
2005 vectra c abs plug location
vectra c 2.2 abs problems
abs ligjt and trachion control light hall 2005 vectra
vectra 2004 abs light
vauxhall signum 2.0 turbo traction control light
vectra c 2003 abs location
