Thread: Vectra c passenger footwell leak
    wolverhampton
    Angry Vectra c passenger footwell leak
    Hi guys lately I've got loads of water in the passenger footwell and I don't know y. Any ideas
    Full Member Big Sig's Avatar
    have you checked the drains by the pollen filter? Pop the bonnet and on the passenger side just below the wipers there is a letter box sized flap. have a look in there and poke about for the drain. Normally the drain blocks up and the water comes in via the pollen filter air intake.
    Or use the search button.
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    Common problem, clean out and all should be well.
    Bri.
    Sep 2009
    Glasgow
    As above. easy fix
    wolverhampton
    Cheers job done
    Jul 2010
    Telford
    Had to do mine last week too
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    If your heater motor is still working ok you got to it just in time.
    Regular Member Exclusive BV's Avatar
    West Midlands
    You know the problem with that rubber drain outlet is the little lip on the inside.
    If it was smooth then the rubbish would just fall right through instead of building up
    New Member boardinbob78's Avatar
    Sep 2009
    leicester
    Just had this prob too, i've just finished drying carpets out with towels and a vax.
    I've cleared out drains in scuttle, replaced pollen filter and also re-sealed my aerial as think water was getting in there too. Gonna try leaving that stupid rubber drain outlet under the pollen filter out for a bit so water should drain better thru that hole without it.
    Only had car about 10 months but think this problem has been building up slowly and i've only just noticed. Water was building up and poured in when i started driving, came in footwells around where bonnet catch is and same on passenger side.
    Anyway, fingers crossed hopefully its sorted now!!
  1. Vectra C 1.9 2006 Facelift - Front Passenger footwell full of water
    By ciscokid75 in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2013, 11:48
  2. Wet passenger footwell
    By aaruck in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 11:13
  3. wet passenger footwell
    By n8sby in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 20:40
  4. Passenger footwell wet in the Vec-B, HELP!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 22:22
  5. wet passenger footwell
    By al21784 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2007, 23:42
