Thread: Blowing/chuffing/leaking injectors
    Engine : 1.9 CDTi
    Default Blowing/chuffing/leaking injectors
    What seals the injectors to the head on a 1.9 CDTi?
    One of mine has what looks like 'coal' around it. I have chipped most of it off so now want to remove it and replace any seals to stop it happening again (On all 4)
    Engine : 1.9 CDTi
    Not to worry, Just found the HOW2 on replacing the copper crush washer Vx Pt No 93178683
    Farnborough, Hampshire
    hi, just did this 2 weeks ago, make sure you buy new washers, new nuts and new cup washers cos they shatter quite easily and that held me up for a couple of days, for a few quid, definitely worth replacing for new. also, i had to change one of the pipes for a new one as the union had failed. they don't really like being reused. it was about £25 for the pipe for the 1st injector (first on left). quite a straight forward job, blob of copper grease on the washer so it sticks to the injector n doesn't fall down into the hole n jobs a good'un. will be apig to start first of all aand i got every possible warning light come up first time round, was ok once the fuel was round the system again
    Engine : 1.9 CDTi
    Any chance of part numbers for the other bits please
    Sorry i didnt think to get them n just asked for the nuts n cup washers that are part of the injector securing assembly n he knew what i was on about
    Bristol
    Vehicle : CDTI 150
    Lee,
    If you've lots of carbon around the injectors might be best to get some 'Deblock Oil' its made by a company called Innotec.
    This is really good at breaking down the carbon; otherwise you may find you cant get the injectors out.
    I've personally heard of a Vx dealership who tried to use an injector removal 'slap hammer' and could not get an injector out. They then attached a hoist to the slap hammer attachment and lifted the front of the car up, still took overnight for the inj to come out. They now use Deblock Oil as a matter of course with great success.
    Some Diesel specialists swear by this.
    Engine : 1.9 CDTi
    Thanks for the tip.
    I have chipped most of it off (Came off quite easy) and my mates garage have used oven degreaser to remove the coal too on other cars as its quite common.
  1. Replies: 0
    Last Post: 15th October 2012, 21:10
  2. Blowing From Injectors
    By yates in forum Engine & Drivetrain
    Last Post: 15th January 2012, 00:06
  3. I'm so chuffing chuffed
    By jb1kenoby in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2010, 22:29
  4. MOT and Chuffing Springs!!
    By Robsey in forum General Chat
    Last Post: 1st April 2010, 22:32
  5. Chuffing Ebayers
    By Old man Jimbo in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2009, 10:34
