Results 1 to 10 of 18
Thread: steering wheel judder when at higher speed
    Regular Member bunsen1's Avatar
    suffolk
    Default steering wheel judder when at higher speed
    any ideas what can be causing this? please list below any tips!
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Might sound too simple but I had this on my Vec B and now getting it on my Vec C at around 80 mph.
    For the Vec B I needed two new front tyres. I was told the original sidewalls were not in good shape. After new tyres fitted it was smooth at all speeds. I suspect the same with my Vec C or it maybe just a balancing issue.
    Again this was just my experience. Im also going to take my motor to a garage near where I work next week for full tracking and allignment check / fix. Been quoted £42 + vat
    suffolk
    well the car has a newish trye ( 6months old) with 7mm tread on the left front and last weekend i got new tyre front right hand side so 8mm tread, they were budgets front left is sunny and front right is diamondback, both are directionals with same pattern treead
    Regular Member Dazzy2006's Avatar
    Notts
    If u havent hit any kerbs its probably 1 of the weights have fell off - i would try to just get the wheels balanced and go from there
    suffolk
    is it standar to when having a new tyre fitted be balanced to? as im sure its worse since the new one at the weekend?
    Notts
    usually they will balance the wheels whenever they change the tyres. something to do with they cant make a 100% round tyre - lol
    suffolk
    lol. thanks. can it be anything else springs or stuff
    Notts
    more than likely balancing - you could always put the front tyres on the back and vice versa(keeping the directional tread the same) and if the vibration through the steering wheel goes u have your answer
    suffolk
    ok mate thanks, i was just thinking there was slight play in ball joints on the last MOT. not when i owned the car and maybe that had got worse, but i know nothing about cars so guessing ( well since owning the veccy i know alot about that now lol, well not lol really more like growl growl growl)
    thanks for ya help mate and glad to see the forum up and running again, nice one
    Notts
    Quote Originally Posted by bunsen1 View Post
    Try swapping the tyres around but when you jack up the front grab the tyre top and bottom and give it a wobble and see if you can feel any play but i still reckon 1 of the balancing weights has fell off or the wheel isnt balanced properly
  1. Steering judder returned!
    By stevie16v in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2013, 15:34
  2. Vectra C Caravan / Estate - higher speed strange sound
    By gmx in forum Bodywork & Interior
    Last Post: 29th December 2012, 19:11
  3. Steering judder at 70mph, possibly solved?
    By twinxster in forum Troubleshooting
    Last Post: 27th January 2012, 22:20
  4. Odd intermittent steering judder/wobble !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 23:34
  5. mpg and wheel judder
    By rob warrington in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2010, 23:30
