Thread: MAF fault code won't clear
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    21 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    Default MAF fault code won't clear
    I have replaced my MAF sensor (Z32SE engine) but am still getting the spanner symbol on my dash display and the same fault code. Does this need to be reset or should it have cleared? If the MAF sensors not the fault, what is? Is it a wiring or plug fault?
    Cheers.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member LADmachining's Avatar
    Hampshire
    If the fault was due to the sensor itself, the light would go out and the fault code would self-clear after 30 ignition on/off cycles, or when cleared with a diagnostic tester.
    Other things to check for:-
    MAF fitted wrong way round (just checking! )
    Loss of power supply / earth to MAF
    Air leak between outlet of MAF and engine.
    Pins pushed back in MAF connector
    Defective wiring between MAF and ECU
    Defective ECU
    Other sensor(s) giving incorrect readings, confusing ECU into thinking MAF is faulty.
    Mechanical fault with engine (valve timing, burnt valves).
    21 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    Oh great!
    Paul
    Hampshire
    Unfortunately, just because the fault code says "Mass Air Flow Meter Defective", this is only a pointer to the area that may be at fault. A load of diagnostic testing is often necessary to pin-point the exact cause of the problem.
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    Quote Originally Posted by GSiFan View Post
    Cheers.
    Paul
    Where did you get your replacement MAF? Brand new from Stealers, off ebay or from a donor car??
    Are you sure this replacement MAF is fully working and functional?
    Bri.
    21 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    eBay, so not sure.
    Paul
    21 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    Ok. Does any of you have details of pin outs for the wiring between MAF sensor and ECU? Where is the ECU? I am going to try to find the problem - whatever it is - and fix it.
    Paul
    Fareham
    Anyone live near you with the same car?? Could try a quick swap of MAF's of a known working one to confirm if it is or is not the problem??
    Bri
    21 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    I had the same idea! I shall ask around.
    Paul
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Clear the fault code and go from there.
  1. Cars Fault Clear At Last
    By Telboy in forum General Chat
    Last Post: 14th January 2013, 11:58
  2. how to clear a spanner light fault
    By tonner in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 21:50
  3. Y30DT Looses boost, clear fault code and back to normal!
    By tommychimp in forum Y & Z30DT Specific
    Last Post: 5th September 2011, 20:07
  4. fault code 7e9 a/t
    By mackemade in forum Engine & Drivetrain
    Last Post: 3rd July 2011, 22:28
  5. op-com to clear ABS and TC fault lights
    By elite3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2010, 23:02
vauxhall insignia fault codes wont erase
fault code wont clear audi a1
how to clear insignia fault code
vauxhall calibra clear fault code
erase insignia abs code
vauxhall zafira 2004 2.0 dti air mass meter earth
