Thread: Hid Help
    Regular Member Dazzy2006's Avatar
    Notts
    Default Hid Help
    I eventually received my hids from hids - direct tuesday but decided it was best to wait until the forums were up and running before fitting .
    Can you hid guru's do me a favor and check the piccy below just to check it looks right before fitting
    Cheers guys
    Regular Member messermitch's Avatar
    Aug 2009
    Yorkshire
    Engine : 1.9Cdti 150
    Thats the same as mine mate. Although i cant get mine to stop strobing after i turn the ignition off, even with fitting 2 cancellors on the same side.
    I'm having the ECU programmed this weekend by a fellow member to resolve this problem.
    Hope it all goes well matey.
    Regular Member DarylAAS's Avatar
    South Shields
    Yep That looks fine mate...
    Engine : 1.9 CDTi
    When/what problems do people get when fitting HID's?
    I fitted a set from my last car and they seem to be fine.
    Turn the lights on and they come on ok, start the car and they stay on ok, turn the car off and the HID's turn off and the car goes onto sidelights.
    Is that right?
    (PS sorry to jump on your thread)
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    thats right mate go for it
    Notts
    Thanks guys - seems i have figured out how to wire them up so hopefully it wont be raining tomorrow and i'll get them fitted then
    Quote Originally Posted by lee gsi View Post
    Is that right?
    From what ive read lee some hids have problems starting up,causing errors,strobing with engine on,strobing with engine off, etc etc
    Fingers crossed they will turn on and off like there supposed but then again im fitting them so maybe ..........................
    Engine : 1.9 CDTi
    What the HOW2 doesnt tell you is how to get the original metal bit onto the HID bulb.
    Do yours have the metal bit fitted already?
    Notts
    Yep - my bulb has the metal base and also my headlight has the spring clip to hold the bulb so i'm hoping fitting the bulbs takes less than a minute
