Results 1 to 10 of 21
Thread: NCDC isnt moving.... (repost summary)
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default NCDC isnt moving.... (repost summary)
    Hi Guys
    before this funny guy messend up the forum
    both Soulman and I had problems with out NCDC radios, that either wasnt moving or was way off..
    To put it short..
    Dont have the satnav ariel on the inside of the roof.. eg. put it at the front of the windscreen, or some other way of putting it on the outside..
    The othe problem was the car claimed it was way of, and the "arrow" just kept spinning around it self of the screen, and the satnav had good connection.
    there the error was the gyro unit, that was faulty inside the NCDC (pic. later)
    The thread was also about the hidden screens.. ill make a write up along the pictures about what is what later..
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    I hadn't seen the original post, but am interested in hidden screens on the NCDC - I know there are some on the newer models but never found them on this one (I have a 2013 as original equipment).
    As for the problem, is there a connectivity problem between the arial and the unit maybe?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    I,m on the look out for a vectra gps ariel base and the correct leads now ......I have found mine works when you plonk the magnetic antenna on the roof .....not something i would like to do all the time ...but i suppose I could put a blue light on it lol .
    Engine : 2.2 Direct
    Quote Originally Posted by MysteryElite View Post
    Press and hold down MAIN for about 10 sec. and the use BC/NAV
    and then it neede to press either main again or was it clear, to get to the screens.. (ill try again later)
    Edit: the arials wasnt the problems.. it was the placement..
    Engine : 2.2 Direct
    Okay the hidden screens
    (and only what i know...)
    First line
    11/3 shows max nr. of satelits, and how many current connected
    HDP0.0 is how acurate the GPS is. (dont know other values)
    DG 03:03 for how long without satelit connection (on picture 3 minuts and 3 sec)
    S0.0 how fast you are driving in KPH (0,1 acurate)
    Line 2
    First with N and E is your excat position
    H+0068 is how high above sealevel (mine 68 meters)
    R0 is the "heading" in 0-360 degrees.
    Line 3 and 4 shows up to 8 satelits and the connection.
    the info on other screens you can find on http://mitglied.multimania.de/hardwarekiller03/lcd.htm
    but pictures of them
    Feb 2007
    North Somerset
    Thanks Ken - I'll have a play with mine and see what I get.
    Engine : 2.2 Direct
    Default what arial to keep
    What aerial to keep now that i dont have a OEM one
    on roof
    Advantage:
    Allways connection
    Disadvantage:
    not OEM
    its Black
    Not very much clearance (about 1 mm when boot open) can cause problems in snow.
    Cant be removed during wash..
    (possible fix, colurcode and move out to the side....)
    On the dashboard
    Advantage
    Can always be there.. never need to move..
    Disadvantage
    not OEM
    Connection can have problems in cities ect.
    Car can "hide" it for perfect connection even on open road.
    (if any has a OEM with all the wires to the NCDC let me know , must be for Signum/Vectra Estate)
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    as per pm Ken ...I will have a look at the scrappies later for you ............just hope I can get one for mine lol .also a ls dash trim ...fingers crossed ..just waiting for plasma now .
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    why you after a ls dash trim mate
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by paulvectrac View Post
    I reasonately aquired a vxr interior and the door card trim is the same colour as the ls trim ..the vxr dash trim is for a facelift and wont fit my sri ..preface....
  1. Replies: 15
    Last Post: 8th January 2013, 10:11
  2. Sorry if a repost
    By Ziggy in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 11:53
  3. Sorry if a repost
    By Ziggy in forum General Chat
    Last Post: 28th December 2011, 15:59
  4. Fuel economy summary...
    By Penfold101 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2009, 14:14
  5. Trip pics and summary
    By BlueRob in forum General Chat
    Last Post: 1st November 2007, 17:14
