Thread: VXR gear knob info required
    Regular Member chuckleuk's Avatar
    Jul 2010
    Swadlincote
    Default VXR gear knob info required
    im after putting a vxr gear knob on my sri and wanted to know if its a direct fit and also does any1 have a part number or know where i can get one from, cheers
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    What engine mate?
    Jul 2010
    Swadlincote
    2.0 turbo
    Liverpool
    I wouldn't mind knowing that too, mines a 1.9cdti
    Oct 2009
    bolton
    Default vxr knob
    its easy yes it can be done but you need the whole stick with the knob, i got mine of e bay it was from a astra so i had to change gaitor a well worth it mod if i am honest hated the factory job, dealer charges 180 quid for knob so best to keep eye out on ebay
    Full Member spennny's Avatar
    Blantyre
    If its a 6 speed then i would presume it will fit, i did mine , and a few others , 30 min job if that , and thats the shaft and knob
    Jul 2010
    Swadlincote
    how hard is it 2fit anychance of someone doin a how2
    Blantyre
    Its not hard mate, i should have done one when i did them ,
    i have a post somewhere i will see if i can find it
    http://www.vectra-c.com/forum/showthread.php?t=82551
    So the way i fitted mine
    If i remember as it was ages ago
    Put the car into gear and remove the gator
    Undo 4 torque bolts that hold it onto the car
    Assuming you also are changing the shaft,
    There is a big thick silver pin , this can be slid out carefully , without disturbing anything
    get 2 x long flat head screw drivers and use one of them to "pop" out the ball joint at the bottom of the gear shaft
    once done it should all just come out,
    Refitting it is vice versa of fitting, except pushing the bottom ball joint back in, this bit can be tricky but also can be done
    Page 2 of my link will show u its fitted
    Jul 2010
    Swadlincote
    ok cheers bud, im jus not 2 confident ar ripping my own car apart, even tho i build cars for a living
    Sunny Dartmoor
    Its from the astra forum but its the same for the Vectra.........
    http://www.astraownersnetwork.co.uk/...ad.php?t=61382
  1. show me your knob (gear knob)
    By justin32 in forum Bodywork & Interior
    Last Post: 10th October 2011, 19:18
  2. Play in my knob gear knob lol
    By paulvectrac in forum Engine & Drivetrain
    Last Post: 16th June 2010, 08:20
  3. T I S info required
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2007, 22:07
