Thread: Help wanted with hids
    Regular Member chuckleuk's Avatar
    Jul 2010
    Swadlincote
    Default Help wanted with hids
    hi guys im after some more info on HIDS for my vectra, it's a 2006 sri could someone please let me know what kit i need and also if i put hids in the standard beam can i also buy a separate kit to put in the full beam or can i just ad extra bulbs into the new balasts, also im guessing some new side light bulbs will b required to get rid of that orange look so can you point me in the right direction for these, oh and one more thing is there anything i can do to the fog lights to make them fit in with the new hids, new bulbs or hid kit required.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I wouldn't recommend using HID's in your main beam due to them being slow to react (for headlight flash etc).
    However if you did want to do it you'd need two kit's, 4 bulbs and 4 ballasts (and 4 bulb failure cancellors if not built into the ballasts)
    Jul 2010
    Swadlincote
    would you recomend just buying 2 of the blueish/white effect normal bulbs so they dont look to out off place then, also do you have any ideas on side light bulbs and what i can do to the fogs, cheers
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    http://www.hids-direct.co.uk/hid-con...its-p-445.html
    This is what you want mate, they also do MTEC sidelight bulbs which will give a crisp white light, btw if you mention Vec-C you may get a 10% discount
    I would just buy a decent set of standard h7 bulbs for the main beam as very few will ever see both on at the same time.
    As for fog light bulbs you could also fit some hids in there if you really wanted
    Jul 2010
    Swadlincote
    will MTEC sidelight bulbs fit straight in with out any warning signs or do i need bulb cancelers, are the HID kits just plug straight in or do i need to do any wiring
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    MTEC's are just normal 501 bulbs and will work fine (problems arrise when you use led's)
    The rest is all plug and play
    Jul 2010
    Swadlincote
    i dont suppose you could do me one more favour john and point me in the direction of a how2 remove front bumper on a facelift
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Jul 2010
    Swadlincote
    what watt do i want 35w or 55w are they both legal
  1. hids
    By SEANYboi in forum Styling
    Last Post: 8th December 2012, 20:09
  2. What Hids
    By Pie Sharp in forum Styling
    Last Post: 5th February 2011, 14:14
  3. Purchasing HIDs Tonight, Advice Wanted Please.
    By chrisschild in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2008, 19:19
