Results 1 to 2 of 2
Thread: Fan Speed 1,2,3
    Sep 2009
    Swindon
    Default Fan Speed 1,2,3
    Getting an intermittent problem with the fan not working on speeds 1,2,3. Checked through it all the other day, thermo fuse is fine on the resistor pack, checked all the fuses and when I plugged it back in it worked, since then it had stopped, starting working again by itself the other day and has decided not to work today
    When I try speed 1,2, or 3 I can hear the relay clicking. What do you reckon a sticky relay, or a dodgy resistor pack, might try cleaning the contacts tomorrow.
    Anyone else had the same?
    Frenchman
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Dodgy resistor pack is common, particularly if your scuttle drain hole has been blocked in the past and you have suffered from a damp passenger front footwell.
    There have been plenty of threads on here over the years!
  1. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  2. Speed limits & speed cameras.
    By kentish_bloke in forum General Chat
    Last Post: 15th February 2010, 21:22
  3. Z22YH 5 speed or 6 speed
    By caigey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 11:56
  4. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
  5. Speed Camera's / Mobile speed traps M6>M61
    By suj786 in forum General Chat
    Last Post: 10th March 2006, 22:38
