Thread: B1454 (AFL) and B2652 (Instrument light)
    Regular Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Default B1454 (AFL) and B2652 (Instrument light)
    Have some fault codes stored, these 2 I dont know what is:
    B1454 - Left Dynamic Curve Light Position Sensor Circuit Malfunction. Does anyone know where this sensor is mounted? This fault only come on occasionally, and when it occurs the lights still works, but dynamic lightning (curve lights) dont work, until the faults dissapear (10 sec - 20 minutes, the small warning light is lit when fault is there) or I restart the car. So no big problem, hardly annoying, but if its easy/cheap to fix, why not fix it
    B2652 - Instrument Dimming Bulb Output Circuit Open or High Voltage. Is this caused by a blown bulb? If so, any hints for which one to look for? Cannot see any faults, but then I only have no other Vectra to compare with
    Apr 2009
    Bergen, Norway
    After some months I BUMP this one
    Anyone?
    Regular Member mann3210's Avatar
    scotland, perth
    it could be a broken wire, i had very similar faults, spent hundreds on parts & it turned out to be a broken wire which was easily repaired @ the vx dealer!
    Apr 2009
    Bergen, Norway
    Quote Originally Posted by mann3210 View Post
    Thanks for quick answer Was your fault related to the AFLs (B1454), or instrument (B2652), or both?
    scotland, perth
    both matey
    Apr 2009
    Bergen, Norway
    Thank you :-)
  1. instrument light fuse ?
    By neilb1 in forum The 'Off Topic' room
    Last Post: 20th March 2012, 10:26
  2. instrument cluster
    By veccyv6 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2011, 19:03
  3. Parkpilot Instrument Light, Tech 2 help needed
    By tramman in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2010, 20:35
  4. Instrument cluster
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2008, 18:43
  5. Instrument cluster
    Last Post: 12th October 2008, 20:02
Opel b1454
Opel B2652
b2652
b2652 vectra c
B1454-00 opel
b1454 opel
b2652 vectrac
B2652 vectra
Vauxhall B2652
Vauxhall DTC B2652-00
left curved light open circuit insignia afl
