Results 1 to 10 of 13
Thread: Hard Core - How well do you know yours?
    spoons
    Guest
    Default Hard Core - How well do you know yours?
    Some help please on hard core....
    Following this thread....
    http://www.vectra-c.com/forum/showth...light=driveway
    My house went from this...
    To this...
    I'm having a concrete driveway laid, but was wondering if they have used the right rubble?
    It was compacted this afternoon... what do you think?
    Does it look the right sort of stuff to hold 4-5 inches of concrete?
    Regular Member elongmoss's Avatar
    Burton-on-Trent
    how deep have they laid it when i had mine done 6-8 inches of hardcore was required to prevent it sagging where the cars usually sit overnight otherwise as long as its 1" or larger should be fine
    hope this helps
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If its 4" deep compacted then it will be fine mate its going nowhere just hope your drains don't need looking at as it will leave a nasty scare digging it up!
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Looks like a mix of MOT1 subbase, "scalping" and larger hardcore mixed in,
    I used just the MOT1 (about 4") subbase under 2" tarmac and its fine under the weight of the Vectra.
    should be even better with a layer of concrete on top,
    spoons
    Guest
    Quote Originally Posted by elongmoss View Post
    hope this helps
    Well, where the driveway was originally they dug up the tarmac and got rid of that, then ruffled up the existing hardcore that was already there and spread it about. I measured that area to be about 5-6 inches
    They dug up the turfed area and left about 2-3 inches deep, but with room for about 4-5 inches of concrete to go on top to bring it level
    I didnt measure how deep it was once they had compacted it
    spoons
    Guest
    Quote Originally Posted by markm View Post
    The builder lad told me they use recycled hardcore from the quarry? but its good enough for this sort of stuff?
    No idea ?
    Glasgow
    We deliver loads of type 1 to people who are laying driveways and roads. Thats what people use to save money its called crusher run.
    Regular Member BIG-G's Avatar
    Oct 2009
    thurso
    what did they use to whack it down with was it a whacker plate or was it a roller.if they used a whacker plate it will not compact it enough and you will get subsidence
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by vectra vxr View Post
    Not necesarily true. I did mine 20 years ago and used a wacker plate, went over it half a dozen times, no problems with subsidence. If they have only gone over it once or twice with a wacker plate you could have problems. If you are having 5-6 inches of concrete on top and only using it for domestic vehicles there should not be any problems.
    3.2 v6 Signum and loving it
    spoons
    Guest
    Quote Originally Posted by Johnsdutton View Post
    I wasnt around when they compacted it so didnt see. I think they used a wacker plate machine, as I'm sure he referred to it during the morning.
    There will be 4-5 inches of concrete on top and needs to hold my Vectra and the Fiat 500...
    I've looked at other driveways they've done and there isnt any subsidence on the other drives, 3 years on...
  1. How many hard core Family Guy fans do we have on here then?
    By John LE in forum The 'Off Topic' room
    Last Post: 12th May 2010, 13:19
  2. Radiator Core
    By jimboy26 in forum Engine & Drivetrain
    Last Post: 16th January 2010, 14:51
  3. Hard-Core ICE Hacking
    By saint615 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2007, 17:02
  4. Something amusing for all the hard core gamers out there
    By bruceybonus in forum Comedy & Humour
    Last Post: 30th April 2007, 20:36
