Thread: Crankshaft Pulley. Worth replacing?
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Crankshaft Pulley. Worth replacing?
    If I am changing the cambelt, waterpump and fan belt. Is it worth changing the camshaft pulley at the same time???
    I know it can be a problem part on the DTIs but do they last on the 1.9 CDTi (120)??
    I believe its a git to remove!
    PRESTON
    cam pulley is held on by a single bolt and as it's a 120, you will have to remove it (dead easy) to replace the water pump. I haven't heard of any issues with the cam pulley on cdti's but the crank vibration damper pulley can give problems.
    Jun 2006
    North West
    Sorry, crank vibration damper pulley is what I meant. Thats the one that can come apart isn't it.
    PRESTON
    Yes it is and does, if the car is high mileage and you can afford too, might be worth changing as a precaution. If it's not high miles, check it for play when it's still bolted to the crank, with the auxillary belt off and change if it's excessive.
    Jun 2006
    North West
    The car is at 95k miles. Is it worth getting a genuine vx one or one from a motor factors?
  1. Crankshaft pulley. Vec c and b ??
    By Lordish in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2012, 18:43
  2. noise after replacing crankshaft pulley
    By postman111 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2011, 17:04
  3. Crankshaft Pulley
    By 123ashleyp in forum Engine & Drivetrain
    Last Post: 5th March 2010, 12:37
  4. crankshaft pulley
    By djsoundman in forum Engine & Drivetrain
    Last Post: 20th November 2009, 12:05
  5. Crankshaft Pulley again!
    By ANDY H137 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 14:34
vauxhall vectra cdti 120 auxillary belt bottom pully refit
