Thread: Help please with my vectra
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Default Help please with my vectra
    Hi everyone I've just taken the battery off to reset the ecu but now my doors won't lock when I drive off my windows won't go up or down off the key and also won't go up or down on there own when you keep your finger on the switch on the window button ??? Can someone please tell me how I sort this problem out thanks
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    david.........just needs resetting mate, there is a thread on here, iirc you press the window button on each window down then up until you hear a beep...............on the autolock you hold the lock button down until a beep is heard, I think
    All the info is well documented in the handbook.
    Not got one? Vauxhall has - edit, or at least they did.
    They've gone and revamped their website again and I can no longer find the handbook, servicing, or oil recommendation pages.
    bridgend / wales
    Great thanks for your help I'll have a look around then and give it a go
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
