Thanks Thanks:  1
Results 1 to 10 of 13
Thread: Detachable Rear Tow Bar
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Default Detachable Rear Tow Bar
    Hi
    Had a Bink's detachable towbar fitted to my Vectra Elite Estate, it all works ok including the interlock to prevent the electric rear tailgate opening when socket is activated. It had the Vauxhall connection kit fitted.
    Do i need to get Tech2 to activate the buzzer and the dashboard indication
    Leicester
    There is not a buzzer or dash indication on Vauxhall's electrics.
    11 Post(s)
    According to the handbook there is a dash light.
    Trailer turn signal lamp
    Control indicator flashes in time with turn signal lamps when towing.
    Does not flash if a turn signal lamp on the towing vehicle or trailer fails.
    Leicester
    I have had a Vauxhall electrics on an 04, 06, 56 and 57 plate Vectra's/Signums. I wouldn't read too much into what the hand book states, they don't have a dash indicator.
    Jul 2010
    Smile
    It always used to be the law that the driver had to be advised by warning light that turn signals are working ok??
    Can remember back in olden times there was an extra pilot light fitted on dashboard
    There was on the 3 Austin Princesses I had . Now that dates me.
    Leicester
    Your right Keefy it is law, but the Vauxhall electrics don't do it.
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    I have a buzzer sound when my turn signal is active
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Dosen't the Vectra do it through the existing light check circuit, i.e the light bulb illuminates on the dash then the GID displays which bulb is at fault?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Maverick View Post
    It was part of the cost cutting measures implimented by VX to remove the indicator, you'll find that most of the pre-facelifts DO have the indicator
    VIP-Member caravaner-tony's Avatar
    Feb 2007
    Corringham.
    Vehicle : Signum Elite 1.9cdti 150
    Engine : ZDTH
    Mileage : 108000
    I have a 05 Signum Design and that has a green towbar indicator light bottem right on the dash when indicator is activated with the caravan or trailer attached. Mine's a Westafalia detachable tow bar fitted by dealer.
  1. Detachable tow bar??
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2008, 19:45
