Thread: Spanner and Car light when ignition is on
    Jun 2007
    Scotland
    Default Spanner and Car light when ignition is on
    Hi,
    Just completed a long journey towing a trailer and when I re-started the car after dropping the trailer off, I noticed the "car and spanner" light was on when the ignition was turned on. It goes out a few seconds after the car starts as does the MIL. I did not notice any fault lights coming on at any point when I was towing!
    I've checked for any fault codes using an ELM327 and OBDScanII but nothing is logged.
    From what I gather, if the spanner is lit but then goes out when car is started this means that the fault logged is non critical.
    So - anyone know how I can read this with the ELM and also put the light out? Is there a generic command I can issue over the terminal window to extinguish the light (The software doesn't let me clear it as it can't detect the MIL light is on or any faults logged)? I'd kind of like to know what the fault was but also just want to put the thing out...
    Thanks,
    Ali.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be the glow plugs if there are fault codes stored. If it's not difficult to start then is probably as you say - it's probably old codes.
    Gazza4
    Jun 2007
    Scotland
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Would it even try and power the glow plugs when engine was hot tho (I thought it was fairely clever and only actually powered the plugs if the ambient temperature was low)? I re-started it maybe 10 mins after driving long distance so engine was still hot.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Don't know if it checks some components for faults on startup though.
    Gazza4
    Jun 2007
    Scotland
    Didn't manage to read the fault code but was able to issue a mode 04 command via ELM scan which turned off the spanner light - I guess I'll just have to wait and see if it happens again. Coudln't bring myself to go to the stealers again.....
    It may have been something to do with the fact I unplugged the trailer board when the engine was running and lights were on (car has the trailer lighting module installed) which could have done something weird...
  1. Light at ignition off
    By kingarthas in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2011, 17:43
  2. Light come on when key is put in the ignition!!!!
    By stuart813 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2011, 11:43
  3. Spanner light on ignition - 3.2 V6.
    By d-suhiti91 in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2010, 12:30
  4. Info light on, ignition off Strange
    By speednut in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 21:50
  5. Ignition Circle Light
    By CristianTM in forum Styling
    Last Post: 17th April 2009, 06:50
