View Poll Results: I have the flat spot under 2000 rpm and
Voters
6. You may not vote on this poll
  • my car has a DPF
    4 66.67%
  • my car does not have a DPF
    2 33.33%
Thread: Could this be the cause of 1.9 cdti 150 flat spot?
    jilava
    Default Could this be the cause of 1.9 cdti 150 flat spot?
    Astra-H 2004...,Zafira-B 2005...,Vectra-C 2004..., Signum 2004...Z19DT| Z19DTH| Z19DTL,Z19DT| Z19DTH| Z19DTL,Z19DT| Z19DTH| Z19DTL,Z19DT| Z19DTH| Z19DTL
    only vehicles with DPF.
    Complaint:Some customer may complaint about slightly reduced low end torque after SPS programming with TIS 2000-DVD, version 83.
    Cause:Latest SPS software in order to improve DPF regeneration strategey (TIS 2000-DVD, version 83) causes modifiaction of engine characteristic, especially during vehicle acceleration.
    jilava
    I also found this in TIS:
    Vectra-C 2004...2005 Z19DTH MT,AF40 Transmission
    Complaint: Bad starting acceleration and bad partial load acceleration below 2000 rpm.
    Cause: Insufficient software adaption.
    Production: Introduction of modified software in production as of the following VIN: - W0L0ZCF6851112054 (07.04.2005) for manual transmission, - W0L0ZCF686XXXXXX (SOP, MY 2006) for AF40 transmission.
    Remedy:
    In case of customer complaint reprogram ECU with TIS 2000-CD as of version 62. For vehicles with AF40 transmission a changed software is available as of TIS 2000-CD, version 64. In this case the Engine Control Unit and the Transmission Control Unit have to be reprogrammed.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    My dpf was blocked upnd had a massive flat spot through the whole rev range an once I gutted the dpf thus has improved vastly and the increase in torque is massive now just pulls all the way to the redline
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    my flat spot was cured by taking out my penel filter and replacing it with a normal one.
  1. CDTI 150 Dreaded flat spot HELP!!!
    By keets in forum Engine & Drivetrain
    Last Post: 19th October 2015, 09:26
  2. Flat spot on CDTI 150-how many suffer from this-*POLL*
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 22nd January 2013, 07:51
  3. 1.9 cdti 120 poor mpg and flat spot at low revs
    By mattclayt in forum Engine & Drivetrain
    Last Post: 17th January 2013, 23:36
  4. CDTi-150 Flat Spot @ 1800rpm
    By Signum7060 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2012, 07:27
  5. CDTI 150, more FLAT SPOT HELP please!
    Last Post: 7th May 2010, 23:28
my 1.9 caddy as massive flat spot when driving
vectra1.9cdti flat spot 2000rpm
flat spot under 2000 revs cdti vectra
1.9 astra flat spot at low revs
vauxhall vectra 1.9 sri flat spots on exceleration
tis 1.9 cdti
