Thread: coolant running temperature?
    Aug 2010
    Leeds
    Default coolant running temperature?
    What is your running temperature when hot/warm normal driving? This is at 85-90 up hills or stationary. 85 on the normal drive but does take 3 miles before it registers off the bottom of the gauge?
    Thinking weak stat or this maybe common.? vectra c 1.9cdti 58 plate 120bhp
    PRESTON
    nope, thats about right. It will take longer than three minutes to start registering when the colder weather comes.
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Sounds normal to me. My 1.8 takes about 5 mins of driving at least befoe my guage registers the temp. Mine normally goes to about 90-95 and stays there.
    Regular Member accveccysriturbo's Avatar
    Jul 2010
    west mids
    Mine tends to be 8-85 on normal driving but can go uo to 90 while in heavey stop start traffic. It soon goes down again once moving though. Mines a 2.0 Turbo though so could be different.
    Sounds right, diesels do take longer to warm up than petrols.
    Aug 2010
    Leeds
    Good just getting to grips with it owned the Astra before but petrol.
    Nice motor and pleased.
    PRESTON
    np, thats what the forum is for, the stupid question is the one you never ask, then wish you had.
    Aug 2010
    Stoke on Trent
    Running to work this morning (35 mile trip) my temp was barely registering and never rose above 80 until I reached the car park at work... only had the car less than a week... is this normal..??
    Nope. Sounds like your thermostat is in need of a replacement. When warm it shouldn't drop back much below 85.
    Regular Member ph67's Avatar
    Northamptonshire
    Bigtee - 85 is about right running temperature and 3-5 minutes running before gauge begins to move is also about right - will obviously take longer to get to 85 in winter - I have a 3.0 V6 CDti and this is what I see.
    Jimbojetset - thermostat sounds like it needs replacing as it's opening too wide or not closing at all when you switch off at night and it cools.
  1. CDTi 150 Running Temperature
    By tony-1977 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 11:38
  2. low temperature and smell of coolant
    By lilangel in forum Engine & Drivetrain
    Last Post: 9th November 2010, 10:55
  3. Running Temperature 1.8 vvti SRi???
    By bigrory1986 in forum Engine & Drivetrain
    Last Post: 14th September 2009, 14:07
  4. Engine coolant not getting to running temperature
    By richard1707 in forum Engine & Drivetrain
    Last Post: 11th August 2009, 23:19
  5. 1.8 sri 53reg Coolant temperature
    By otto in forum Engine & Drivetrain
    Last Post: 9th May 2009, 13:07
