Results 1 to 10 of 16
Thread: Vectra c 58 plate any known problems?
    Aug 2010
    Leeds
    Default Vectra c 58 plate any known problems?
    Hi brand new on here!
    Just got the vectra c 58 plate with just 5k from new it drives fine which it should but reading the net seen it may have a DPF fitted?, It's a manual 6 speed 1.9cdti 120bhp.
    Also when taking corners a little sharp the rear end doesn't seem to grip the corner like the astra did is this normal?
    Any other known problems with this car to be aware of as it's still in warranty, Many Thanks..................
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If you open the driver's door and look at the black plate, along with the axle weights you will see a number either 0.5 OR 1.20,
    If 0.5 You have a DPF
    If 1.20 You don't have a DPF.
    Hope this helps.
    Gazza4
    Aug 2010
    Leeds
    All i could see was the 4x weights and at the bottom left of the stcker was 1.30 in a square box & 88kw next to it?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Bigtee View Post
    I would say you don't then, the 150 says 1.20.
    Gazza4
    PRESTON
    if yours is a manual hatch, no dpf, only the auto hatch and estate have a dpf. 120's are pretty relieable, main things are DMF and EGR valve.
    Aug 2010
    Leeds
    Thanks how long roughly does the DMF last on these before they disintagrate? And the egr valve does this stick like the rest?
    PRESTON
    egr valves stick , yes like the 150,s. Personally if its failed or failing, get a new one (prices aren't as bad as they once were) and clean the boost sensor while the EGR valve is off, as you can get to the fixing bolt easier. Many have cleaned EGR's only to have other issues or it doesn't last long. DMF's, well, $64000 question really, some have failed as low as 7k other cars have 150k no issues. Mine has 105k and so far, touch wood, DMF ok. They do give ample warning by getting noisey first, some members here have had rattling DMF's for thousands of miles.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by barney490 View Post
    Some the later CDTI 150 manual hatches have them don't know why some do some don't.
    Gazza4
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Deffo a 120. '88Kw' equates to 118bhp which is the published bhp figure (equal to 120PS) for that engine.
    Aug 2010
    Leeds
    Thats great thanks, Any other known isuees with this car?
  1. 53 Plate Vectra Problems
    By Ssc456 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th November 2012, 13:20
  2. gearbox problems sri cdti 150 56 plate
    By kamazoo in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2012, 19:24
  3. Engine problems with my 56 plate 1.8 VVT
    By typo_44 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2012, 09:57
  4. Rear spoiler from an 02 Vectra fit my facelift 56 plate Vectra???
    By Coupe2T in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2011, 18:07
  5. 06 Plate Vectra
    Last Post: 31st October 2008, 14:47
vectra c estate known problems
