Thread: vectra 2.2 engine management light
    Oct 2009
    swindon
    Default vectra 2.2 engine management light
    whilst driving home from holiday car seemed to hit a flat spot seemed to jump similar feeling to taking off the cruise control this only happened for a split second spanner light came on but car carried on as normal at 70mph for a further 150 miles light goes out when engine restarted any ideas
    Regular Member squekey's Avatar
    bedfordshire
    not 100% sure mate but could be HP fuel pump or fuel reg as my car does exactly the same thing, its been into vx for the recall on the faulty fuel regulator which has been replaced but car still suffers the judder at 3500 - 4000rpm my eml comes on but car doesnt go into limp mode, light goes off once key has been taken out and car is restarted. vx had the car back done tech2 on it and have said the hp fuel pump is at fault.
    Mileage : 000
    Might just have been a glitch. Can you get the codes read. Or try the "pedel test". It might work on your motor, then look up the code on the internet.
    Jan 2010
    glasgow
    if it happens agian then id say get the codes read or find some 1 local to u that will read the fault codes for ya
    Oct 2009
    swindon
    hi sorry not sure what the pedal test is can you give me more info cheers
    Bradford
    Trim : Elite Auto
    Engine : 2.2 Direct Petrol
    Quote Originally Posted by jonahstfc View Post
    Hi...
    Did you ever get to the bottom of this?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds like a glitch if its not happened again but if its a common thing I'd be looking at the HP pump and or Reg on a 2.2 direct.
  1. 54 plate vectra 2.0 DTI engine management light on
    By danny 77 in forum Engine & Drivetrain
    Last Post: 22nd January 2013, 18:46
  2. Vectra c engine management light
    By Mark Curran in forum Engine & Drivetrain
    Last Post: 16th May 2011, 11:39
  3. Vectra c engine management light on and no power
    Last Post: 13th May 2011, 15:28
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. Vectra B 2.2 SRI DTI Engine Management Light
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 10th January 2008, 19:08
