Thread: The dreaded P1191 code!!!!
    Plymouth
    Default The dreaded P1191 code!!!!
    Been having problem with my 2.2 Direct 06 Vec randomly cutting out. Thankfully only at low speeds. Fails to restart initially, then finallly springs back to life after a few minutes, then runs fine for a while.
    Been and had it plugged in and the dreaded P1191 code has appeared. HAve been told the ony way to fully solve the problem is to replace the HP Fuel Pump, fuel sensor and fuel regulator! I see £££ signs flashing in front of my eyes!!
    Any thoughts on the diagnosis?
    Regular Member squekey's Avatar
    bedfordshire
    Hi oggiejmx
    vx recently done a recall on the fuel regs - worth giving your local vx dealer a ring and see if your car was under the recall batch number
    HP fuel pumps are prone to failing on the these cars as vx used faulty ones originally but will only recall for the fuel reg and will not replace hp fuel pump unless the car is still under warranty with them. vx know they have used faulty parts but are opting to replace the cheaper parts only rather than do the decent thing and rectify their mistakes.
    Jul 2010
    ashford
    hi,ive had exactly the same problem mate,did you have a lumpy idle?vx replaced the regulator,no difference.this morning i put a new pump on,still no real difference.only the sensor to do,and im not sure that would make it run the way it does,if anyone thinks any different then please tell me.im pi**ed off with this pile of sh*t car.
    Plymouth
    has not been lumpy on idle, runs smoothly until it decides to give up.
    MAte runs an independant garage and he has spoken to his contacts at an independant vauxhall specialist and they say only way around the problem is to replace all three parts. Not going to bother chasing the recall because they will rip me off on the rest of the work.
    lutterworth
    PXED a mondeo zetec for simialar problem all to do with exhaust gases recirculation. egr valve. oxygen sensor . car kept cutting out aproaching junctions
    Jul 2010
    ashford
    sounds like i need to get the sensor then,any idea of the price anyone?
    Plymouth
    Sensor around £100 i think. I am not expecting the bill for all three to be very cheap!
    Jul 2010
    ashford
    100 quid,jesus thats a rip off,its only a small sensor.this car is going mate.its by far the worst car i have ever had.
    bedfordshire
    oggiejmx
    worth giving vx a bell though mate cause if your car is under recall then you will get the new fuel reg fitted plus they will do a diagnostics all free of charge saving you £100+ money is better in your pocket than theres mate and trust me if you can get anything free of charge from vx then its all good!
  1. P1191 - Fuel Pump or Regulator?
    By danhariga in forum Engine & Drivetrain
    Last Post: 27th August 2013, 20:01
  2. Error code P1191-52
    By kenp in forum Engine & Drivetrain
    Last Post: 8th May 2012, 21:48
  3. Oh no - P1191 - Fuel Pressure
    By nibblitz in forum Engine & Drivetrain
    Last Post: 13th October 2010, 21:38
  4. 2.2 Direct (Z22YH) - P1191 Error
    By johnmac in forum Engine & Drivetrain
    Last Post: 2nd April 2010, 00:40
  5. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 16th October 2008, 20:14
