Thread: Parking Sensors stopped working, Please Help?
    Jun 2009
    Brighton
    Unhappy Parking Sensors stopped working, Please Help?
    Hello all. Not sure if i'm putting this request in right place? This is 3rd time asked, hopefully a response this time.
    My parking sensor system stopped working. I think they are factory fitted, as all wiring is very neat with exterior wires in plastic trunking. The symptoms are; when reverse engaged just a single slightly long 'bing' sound with the switch lighting up (the one to manually turn on/off the system). The dash light also comes on (a P with wifi type symbol next to it) I believe these means a fault.
    Here is what I've done:
    Fuses OK; I took all 8 sensors off and tried to measure with meter but not sure what resistances I should find. They appear similar; 1-3 MegOhms typically between pins 1-3 and between 2 and 3. There is a very fixed 6 kOhm between pins 2 and 3. When system is on with engine off (i put in reverse) if you put your ear to the sensors I can hear a low frequency pulse as mentioned elsewhere on this forum I? Does this mean sensors OK? I noted a BOSH box in the little stowage area near rear light clusters. It does not say anything about parking but has the number 965 in a circle which is also on the sensors themselves? Is this the sensor control box?
    Any tips on how to check the system out? Can it be tested? Has anyone got a circuit diagram for the OEM system fitted to the estate model??
    Full Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Quote Originally Posted by Snizzers View Post
    I have had similar problem..
    Took it to the stealers and they put the Tech2 on it and told us it was the sensor outer right side at the back that was faulty.. New sensor and it worked again...
    2006 Opel Vectra C OPC Estate Arden Blue 255bhp Heated full leather Climate control Full powerflex rear suspension Power tailgate Retractable Towbar Eibach 30mm Original BBS RS-GT 2-piece forged 20" with 225/35 front and 255/30 rear HID 5000K Autolights Rainsensor Dim rearview mirror Heat reflective windscreen 280bhp airbox mode Tinted windows PDC
    [Ex]Admin Duncan's Avatar
    I had an aftermarket kit (Cobra) on mine which developed a fault and it emitted that long continuous tone instead of the normal interrupted tone.
    The issue with mine was the wiring to one sensor had become corroded at the sensor end and broke the connection. On these systems if one sensor is disconnected/broken then you get the continuous tone.
    Yes. that's the simplest way to verify whether each sensor is working. When in reverse just take a finger and touch it on each sensor, you'll feel a vibrating pulse if it's working correctly. On mine one wasn't so I knew to look further at that one and found the corroded wiring. Hopefully you'll find one that isn't pulsing and it'll be an easy fix - mine was to simply buy a replacement sensor as there was no way, with the way it was wired and the tiny plug it used, that I was going to be able to solder it.
    Engine : 1.9 CDTi
    Put it in reverse and bend down and have a listen at the sensors.
    You should hear a clicking noise if they are working.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by lee gsi View Post
    But make sure the handbrake's on, wouldn't want to hear it warning you're about to run yourself over........
    Jun 2009
    Brighton
    Thanks for all replies. I eneded up getting Vax to look at it. They found the rear drivers side sensor failed. It was replaced and now OK. £135 for parts dignstic an labour.
    Aug 2010
    Antrim
    OMG, you could have got sensors fitted to a car without them for £135!!!!!!!!!!!!
    Was just thinking the same! £135 seems extremely steep just to sort out a single sensor, although once you break it all down I can see how they get to that figure.
  1. Sat Nav Stopped Working
    By alhambra in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 19:24
  2. parking sensors not working
    By gsi-robster in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2012, 18:57
  3. Parking Sensors stopped working
    By Snizzers in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2010, 18:52
  4. parking sensors and power sockets stopped working
    By charliepirate in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2010, 13:37
  5. Parking Sensors stopped working
    Last Post: 30th May 2010, 09:43
