Results 1 to 10 of 11
Thread: Where to put axle stands on front?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Where to put axle stands on front?
    May seem an odd question to most of you , but I bought a kit off Halfords with a trolly jack/stands etc, and am going to change the oil soon. In the past ( hangs head in shame ) I have always driven the cars I have owned up on blocks, and squeezed under that way, not very safe I know , and not a lot of room for leverage ( have mangled sump plugs in the past ).
    So if anyone has any diagrams or pics, or idiot guides as I have only ever done basics on cars - oil - filters - coolant renewals. I would be greatfull.
    I put mine on a bolt on the lower suspension arm. Engine end
    Oct 2007
    south wales
    on a bolt ?
    Yeah where the arm fixes to the car. They are big and secure so won't bend or break. Not sure if it's the best place just I find it convenient
    If you look at the front of the car you will see two small triangles impressed into the sill
    Follow these under the car and you will see a square with a hole in the middle
    This is the lifting point
    There is a similar one at the rear
    Follow the "usual" health & safety guidelines when working under a car; get some other muppet to do it!
    Oct 2007
    south wales
    I know where the jacking points are, and Ed kindly provided me with some plastic inserts for my jack ( which work a treat, cheers Ed)
    , its just whereto put axle stands that I need to know.
    PRESTON
    Huddersfield
    Which Vectra do you have as I tried to do an oil change on my 2007 Cdti Estste and couldn't due to the cover underneath. In the end I had to borrow my uncles pit so that the cover could hang down. Try www.national.co.uk for a cheap oil change if you get stuck.
    Oct 2007
    south wales
    Quote Originally Posted by Paulrushton View Post
    Mine is a 1.8 vvt, so shouldnt have that problem...
    Quote Originally Posted by barney490 View Post
    What penfold suggests there is where I place mine.
  1. Front jacking points, and using axle stands
    By PeterVV in forum General Chat
    Last Post: 25th July 2017, 14:27
  2. Axle stands.
    By weverall in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2012, 16:25
  3. axle stands
    By liam2.0dti in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2009, 23:23
  4. Axle Stands
    By cp123 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th November 2007, 11:51
  5. axle stands - where to put them ????
    By Nickzx6r in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2007, 21:24
put axle stands vectra c
where to put axle stands vectra c
where to put axle stands on vectra c
