Thread: What is this little black box in my engine bay?
    Regular Member Innes's Avatar
    Plymouth
    Default What is this little black box in my engine bay?
    Hi guys, I have a pre-face 2.2dti SRi and recently posted a thread showing my new silicone vacuum/boost pipes and one of the guys asked what this little black box was as they dont have it in their car. Admitily he has a 2.0dti but as far as I know the 2.0 and 2.2dti engines are near identical. Its part of the vacuum system but really dont know what it is.
    Any ideas chaps??
    Regular Member elongmoss's Avatar
    Burton-on-Trent
    i think its the vacume pump cant be sure though would have a look at mine but its raining hear
    Its possibly a vacuum reservoir, I dont know for sure but it is not the vacuum pump. That is mounted on the end of the cylinder head and is driven by the end of the cam shaft.
    Plymouth
    anyone else got any ideas what this is. Can any 2.2dti owners check to see if they have it aswell?
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Its a vacumn resovoir
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Thanks for the info alan .
    Innes that has cleared up a long standing question from another member who had purchased a vec from an auction , all this vec had was the hose which leads to this reservoir but in this case it had just been sealed up .
    out of interest what year is your vec it must be an early one to have that setup
    Regular Member benny's Avatar
    Feb 2006
    dudley
    its a vac resovoir it is mainly used when shutting the engine down when the engine is turned of the inletmanifold flap on the inlet manifold is shut allowing for a quicker shut down ...beeing as the engine is off the vac pump wont be giveing vac so it needs a tank to store it up ....if you run the enigne and get some one to turn it off while you stand at the front you will see the inlet manifold flap close then a few secounds later it will make a sound like a slight his / click then the flap will open ready for the next engine start ...
    Plymouth
    superb bit of info. Thanks. My vectra is one of the first. Its november 2002. Probably explains why no one recognises it.
  1. Two black boxes near top of engine on v6 cdti
    By jock in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2012, 20:54
  2. help please black smoke from engine
    By tigertye in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 12:34
  3. Black soot/smoke when revving the engine
    By tigro in forum Engine & Drivetrain
    Last Post: 30th October 2010, 14:41
  4. engine chokes every now and again and black smoke problem
    By Paddyrallyhead in forum Engine & Drivetrain
    Last Post: 5th July 2010, 20:54
  5. Diesel Engine Oil Black??? HELP!
    By s0501291 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2009, 22:45
insignia vacuum reservoir
vectra 2.2 vacuum pipe front of engine
vectra c vacuum reservoir
modified cdti v6 vauxhall vectra engine bay
vectra vacuum box
vacuum reservoir vectra c
