Thread: Switchable remaps
    Wales, UK
    Default Switchable remaps
    Hi all,
    Warranty will be ending in the next 12 months and considering a remap !
    Im sure there is a member on here, might be something like ChrisK, only I cant find him on the list ??!!
    Think he may have had the dealer load a new map onto the car and fitted a sport switch somehow wired it to the switch. Very imterested in this. I like the idea of pressing the button for a bit more power, should you want it and the rest of the time, using the car as normal.
    Looking for some advice and options.
    Thanks all!
    WGAF#5
    the vxrs have a sports switch that can allow the map to work on the button when pressed - but if its not already there it probably wont work
    as a sperate entity - i suspect that the best option would be a ppc /bluefin type device which will allow you to remove and reinstall the map - but only when stationary (for about 5 minutes)
    if you CAN get it to work on a button it would be superb
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Quote Originally Posted by mark_647 View Post
    Hi all,
    Thanks all!
    I have the EDS-IPF which allows the swapping of the remap from a pc or laptop. takes around 45 mins. If you have a standard 150 without sports button you can have a 190 or 200PS map and change back and forth whenever you wish. If you have a sports button equipped car it is switchable on the button which is great if you have it.
    CHRISK.....now OPC
    Wales, UK
    Think your right, ive been looking into it this evening lol I priced up a bluefin, like yourself, the EDS is a little cheaper.
    Do you think the Bluefin is a better choice ?
    Quote Originally Posted by OPC View Post
    CHRISK.....now OPC
    Ah, the name change explains it lol Guess the button is out of the question then !!! I remember reading MCD's write up after his EDS remap and it was very positive...
    Thanks both !
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    I can most definitely confirm the EDS remap is excellent. Very smooth with no flat spots of any kind. There is the usual surge in power from aroound 1750rpm and a massive boost around 2.5k to 4k and even up to 5k if required. I would say fuel consumption is only increased when taking advantage of the extra power as nprmal driving sees no different.
  1. Switchable exhaust
    By Ziggy in forum Petrol Engine related
    Last Post: 2nd October 2012, 19:40
  2. Adding switchable TC?
    Last Post: 10th April 2012, 11:38
  3. Switchable traction control help
    By PANDY 3.2 V6 in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2011, 12:11
  4. Vectra V6 diesel switchable 4 cylinder: EXISTS ?
    By Dave777 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2008, 00:53
