Thread: Are Coil springs relitively easy to install?
    Jul 2010
    Lossiemouth
    Default Are Coil springs relitively easy to install?
    hi all,
    quick question, managed to get hold of a set of eibach 30 mm lowering springs for my vectra c. heres the thing ive never changed springs before , got a copy of haynes manual and i was wandering if it was reletively easy to change myself using that or is it worth getting loacal garage to do them for me?
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Rears are easy to do, but the fronts require the aid of a set of spring compressors. If you got a set its an easy 2, maybe 3 hour tops, job for a the home DIYer.
    Edinburgh
    Should be able to do it yourself no probs. Just need spring compressors as mentioned. Be careful though cause if they slip out of them, it'll go off like a rocket.
    Huddersfield
    I used the Lazer spring compressors and found them really good. I got mine online but Halfords sell them.
    Don't scrimp on cheap compressors. If the spring slips it could literally kill you with the force it's under. Best case you'll cause serious damage to whatever it lands on.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    As mentioned you must have the adequate quality tool. Going to cost 30 odd quid or so i suppose. Might as well just pay a good mechanic unless someone can lend you the comp.
    Without adequate equipment, nevermind diy it could be kill-yourself.
    chorley
    Don't forget when the springs are changed you will need the camber/toe setting checked and adjusted if required --- unless you want excessive tyre wear.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Hi Leo....would the standard shockers need changing also ????
    Thinking of possible shock absorber 'travel' length problem with shorter springs>
    Jul 2010
    Lossiemouth
    spot on thanks for that, think the old boys got a set of spring compressors knocking about. ill let you know how i get on!
  1. is it easy to install rear electric windows
    By P11CRG in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2012, 20:19
  2. coil springs
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 29th December 2010, 19:48
  3. will it be easy to install
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2008, 20:04
