Thread: glow plug removal
    Regular Member dieseldave's Avatar
    Apr 2008
    aldershot hampshire
    confused glow plug removal
    Hi guys do any of you know of an easy way to access the glow plugs from a vectra c 1.9 8v as i have tried but it seems an impossible task as i can't get access to them do any of you have any decent pics from start to finish.
    your help in this would be gratefully accepted or if any of you wana come round and help us
    PRESTON
    havn't changed mine yet and dont really want too, it is tough to get at them, damn silly place to put a serviceable item. I hear that they can be got with a deep socket on a long extention bar with a swivel on the end.
    We really could do with a how to on this for the 120's
    Regular Member pugs,signum's Avatar
    swansea
    im guessing its not the same as the 1.9cdti (150) engine? that took a 9mm deep reach socket on a quarter drive t-bar and bob's your uncle!
    Im guessing its at an pain in the arse angle? and they can snap if the pressure aint right when you undo them
    PRESTON
    it's not the same as the 150, no. They are nice and easy on top of the engine, 120's are shoved right round the back under everything, grrrrrrrr!!!!!!!
    i think the 120's need a 7mm socket, i,m sure they have a different size head and are a much shorter plug than 150's.
    found this on a thread from Nov 2009;
    take the egr valve of to get to cyl 4 and for cy1 & 2 their is a small fuel block on the manifold that might need to come off its held by two t30 torq bolts. even then a little fiddley
    Apr 2008
    aldershot hampshire
    i have tried it on my 120 but its a pain in the arse as they are right down under the inlet manifold think they are a 10mm deep socket just the angle is a bit tgt to get onto them.
    need to find and easy way to do it as don;t really wana start stripping the engine down again as i have just had to put in a new injector clamp stud and injector which was a pretty easy job
    PRESTON
    yeah, 10mm deep socket, i checked too and boy are they hidden, even with taking off the egr and that fuel block they look a nightmare. I was wondering if it would be easier from underneath if the car was on a ramp.
    Apr 2008
    aldershot hampshire
    hi barney 490 don't think it will be any easier as you will need to come in from the top of the engine some how
  1. Help needed!!! Glow plug lead removal 2.0dti
    By FLOB in forum Diesel Engine related
    Last Post: 17th March 2012, 18:24
  2. Glow plug removal + elec fault
    By mr.c72 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 22:23
  3. Glow Plug Removal
    By dhwigston in forum Engine & Drivetrain
    Last Post: 1st December 2009, 14:30
  4. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  5. glow plug
    By dominic32 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 21:46
vectra c glow plugs removal
vectra c 1.9 cdti glow plug removal
