Results 1 to 10 of 18
Thread: Afl Headlight Bulb types..
    Regular Member VeCCtrA's Avatar
    Turkey
    Default Afl Headlight Bulb types..
    Below my car's photo (2005 GTS 2.0T). I fitted newly afl headlights. All functions are working.. But i wonder what type of bulbs that cornering lights and high beams ( H1, H11, or what ) have.They are different from old ones (H7) And i couldnt open indicator bulbs cover, how can i open ?..Anyone know those ?
    Turkey
    And i wanna ask something. I bought them from UK thats why light screening is inverted. ( our traffic is goes from right, yours from left) Beam should be like this..
    But mine is mirrored to left-right.. Some people say you can fix it easily. Do you know the way to fix it ?
    They should be xenons in those as thats what they came equipped with if they were a factory option. On the non afl lights there is a little lever under the bulb cover to flick over.
    Turkey
    Are you sure there is no lever in my headlights to set them left handed driving ?
    Anyone know where is that lever pls help..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    to switch its abutally a fuse you either have to put in or remove on the AFL.. (cant remember witch.. check manual..)
    You cant access the indicatorbulp sorry, but thats how it is.. (another user fikse have been looking in to this)
    Turkey
    Quote Originally Posted by kenp View Post
    Thanks, i read that from manual. I will try it...
    Engine : 2.2 Direct
    May i ask what you had to change to get all the AFL working on a prefacelift as im interested in that.. (also if you get the wrong light distribution sorted)
    Turkey
    Headlights, sockets, cable connections ( according to tis 2000) hll control unit to afl control unit and aluminium units that under the headlights...
    Also i checked my fusebox, number 37 is about afl light distribution really. I will fix it today...If you insert any big size fuse to 37, it makes rhd to lhd and activate afl light on dashboard. Thats what i forget to consider...
    Engine : 2.2 Direct
    And you didnt have xenon before? or did you have that?
    Turkey
    I have had original xenon before. If i didnt i would need xenon height sensors front axle and rear axle, xenon type switch, ballasts and etc.. Do you have xenon ?
  1. Anyone know of a web site that lists bulb types
    By PeterVV in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2009, 18:44
  2. Which bulb types for facelift?
    By muffking in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2009, 15:45
  3. Headlamp Bulb Types
    By ANDY W in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2009, 17:28
  4. Replacement Bulb Types. Still Confused. H7 or H1
    By 67688c in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 13:40
  5. Bulb Types
    By Marky in forum Styling
    Last Post: 13th November 2006, 18:33
afl control unit indicator
vectra c afl
Signum afl Xenon
opel vectra afl bulbshow to change bulb light right vectra copel afl2004 signum afl high beam bukbvectra c opcopel vectra c aflafl headlights vectra cafl factory headlightshow to turn afl headlights on vectra 2004vectra c afl high beamsignum afl headlightssignum afl2004 signum xenon type2004 signum afl headlightopel vectra 2007 aflvectra afl indicator bulb type
