Thread: Divorcing stereo (Just a quickie)
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Divorcing stereo (Just a quickie)
    If a stereo has not been divorced from the car / previous screen, is it a problem getting it married to a new car or is it just a tech2 session?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If it's not divorced then you will have to get code from car it came from or send it away to get set to delivery mode
    Irmscher Insignia CDTI 130
    Tain - Easter Ross
    Even on full canbus?
    And if its a stereo with a display and my old stereo was not divorced, is this code required?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If you have both radio and screen from donor car then they will fit without a problem
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    The general answer is.
    If you are fitting JUST a screen or JUST a headunit that is still paired to a previous car, then you have two options.
    1) Get the audio pass from the previous vehicle, and use this code to get it Tech 2 divorced / cleared.
    2) get the component read via Tech 2 or Op-com, to get the original vehicles chassis number.
    Then take this number along with £15 to Vauxhall, who will get you the audio pass code after a couple of days. Use this code to divorce the screen as described above.
    Then using your own car's audio pass code, you can get it tech 2 paired to your car and the other part of the infotainment system.
    If you are fitting BOTH headunit and screen which were still paired to a prevous vehicle, then they will work fine.
    If you are upgrading from TID to GID, then you may need to add an extra red and an extra brown wire to the 32 pin screen connector - there are loads of threads describing this...some by me
    It is not unheard of, for the speakers to crackle or pop occasionally for the first five minutes after turning the radio and / or ignition off.
    After these 5 mins, all but memory power is cut by the BCM and CIM.
    If your existing screen and display were just removed without tech 2 clearing, then this is no problem.
    The screen will retain your car's settings, ready for if / when you wish to refit them to the car.
    I have successfully fitted a CD70 and GID to both a Vectra-c and later a Cavalier Mk3 with no problems.
    The speakers did pop in the Vectra...but not in my Cavalier.
    The CD70 and GID were still paired to a Signum. They still are!!
    Hope that helps
    Tain - Easter Ross
    Sorry, I was vauge there, if the old stereo (full canbus) was not divorced from the screen still in the car and I bought a replacement stereo with a screen (not one with the BC) what would be involved? Codes? or just a good licking with the wonder toy tech2?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Im getting confused lol
    If you are replacing both stereo and screen with a paired replacement eg:from same car it will fit straight in
    If you want to enable BC functions then you are going to have to find out the code for radio because if you want to alter any settings regarding screen or radio you will need their security code
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    So you are keeping your screen and fitting a new headunit.
    If your new stereo is divorced, then you will need to tech 2 program it in to match your existing screen...you will need your own vehicles audio pass code.
    If the screen and headunit are still paired, then you will need the audio pass code that they were paired with.
    Use this code to tech 2 divorce the headunit.
    Then pair to your existing screen with tech 2, using your own cars pass code.
    Is that better?
  1. Divorcing and marrying a sterio
    By owen_999 in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2013, 21:16
  2. divorcing without car pass?
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2013, 21:03
  3. Divorcing HU
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 14th December 2012, 23:54
  4. Tech2 divorcing/virginised - Can anyone do it?
    By L11Marc in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2010, 18:59
  5. divorcing screen from radio
    By pubcarking in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 21:13
