Thread: Where is the Aircon Drain pipe?
    Jul 2010
    Leeds
    Default Where is the Aircon Drain pipe?
    I'm after a quick pointer to where to find the pipe that takes the Condesation water out of the Vectra C to the outside.
    My car is filling the drivers footwell with water. I'm sure the end located behind the dashboard has split or come off where it's supposed to be.
    I've checked behind the wiper under the flap and that drain is OK.
    Trying to avoid a wasted/expensive day at the dealer if two screws and common sense can fix.
    I have never looked but on other cars it's always been found hanging down in the centre of the car near the bulkhead between the engine bay and passenger compartment.
    Ashington, Northumberland
    It is on the bulkhead on the drivers side. When you look at it, it only sticks out of the bulkhead about an inch and the end of it is '+' shaped. Look just above the steering rack when you're trying to find it
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    After the recent rains, you might do well to check that the scuttle drains are clear and that the footwell water isn't coming in via the pollen filter housing.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Handyandy-UK View Post
    That would be my though, or the windscreen seal letting water through. The only other time I've heard of water in footwell is from a heater leak.
    Huddersfield
    I had this on two CitroŽn C4's (one if several thousand common problems). You'd be amazed how much water it can empty into the car. I got two buckets out with the wet and dry vac and the carpet was still sodden. Don't think either ever dried fully. I used a stiff metal coat hanger to clear the tubes.
    Jul 2010
    Leeds
    Thanks for the tips - I'll check it out tonight
    Regular Member Exclusive BV's Avatar
    West Midlands
    Regular Member old cruiser's Avatar
    slough
    Have you checked the drain hole on the drivers side mate as a lot of people don't as they 're not aware that one is even there,; not that easy to access unlike the passenger side, but if you look down thru the honeycombe part of the water deflector where you can see a part of the wiper linkage it's tucked down in there.HTH read thru this post it might help http://www.vectra-c.com/forum/showth...ide+drain+hole
    Cheers Pete
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  3. 2nd Drain Hole?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 21:05
  4. CD 70 Navi Drain
    By pikolim in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2009, 15:39
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
opel corsa aircon drain pipe
vectra c ac drain
wheres the ac drain on a vectra c
opel vectra c ac drainage location
2005 opel corsa aircon drain pipe
air con discharge vectra
opel corsa ac drain outlet
opel corsa AC drain line location
vectra c air con overflow pipe
opel signum air con drainage
where is the aircon drain on a 2012 opel zafira
