Results 1 to 2 of 2
Thread: Swirl Valve / Inlet Manifold 1.9 CDTi 150
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Swirl Valve / Inlet Manifold 1.9 CDTi 150
    1). Can the swirl valve mal-function at any time and are there any signs that it is starting to play up?
    2). If it mal-functions whilst away on holidays towing, would the car still be driveable to get me home?
    3). What are the symptoms of it failing?
    preston
    Smile
    hi
    mine went about 50K
    take the cover off your engine and look for swirl bar.
    Is it still attached. If its on its side then yes its died
    If its still on check all four pins. Maybe one will be off?
    Get someone to rev engine and check the actuator still moves bar ( its controlled from 3rd pin )
    look for greasy / oily mess around the top of the swirls on manifold....usually a giveaway of failure or failure to be
    signs are usually hesitancy initially then spanner light + limp mode until the problem is resolved
    In the end i just took mine off, spanner light went away and yes it drove fine, just a slight loss of real top end power
    I run without it now until can afford new manifold ( resdesigned ).
    Other issues i'd check whilst there
    EGR valve strip and clean ( follow how 2's for all these )
    boost sensor clean
    check boost pipes from vacuum pump
    check intercooler hoses
    trouble is so many of the faults on the 150 seem to have similar symptoms that its really a question of checking things in a logical manner until you find the culprit / culprits
    Have you had the spanner light on? IN that case you should have code to read - again follow how to for free code read then post back here and someone will give you more detailed advice
  1. Inlet manifold swirl rod.....
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 16th September 2011, 16:02
  2. Inlet Manifold - Swirl Flaps?
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 5th April 2011, 23:38
  3. Inlet Manifold / Swirl Bar Help for 1.9 150
    By tilleyedie in forum Engine & Drivetrain
    Last Post: 18th February 2011, 01:13
  4. Inlet Manifold / Swirl Valve DIY Replacement
    By jon page in forum Engine & Drivetrain
    Last Post: 19th April 2010, 07:26
  5. inlet manifold / EGR valve/swirl actuator
    By John-joe in forum Engine & Drivetrain
    Last Post: 10th August 2008, 19:33
vectra swirl valve symptoms
